Question about Maytag MGS5870 Gas Kitchen Range
HOW TO ADJUST AN R V LP GAS AUTOMATIC CHANGEOVER REGULATOR
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: how to adjust gas regulator
The center part of the regulator...
Make sure that you have the gas turned off...
Then turn the center part out and flip it up side down and then turn it back in till it seals...
Turn the gas back on and then check for leaks with a dish soap and water solution... if it blows bubbles it is leaking...
Heatman101
Posted on Mar 05, 2010
Why is it no matter which way I adjust the oven's spud orifice, the burner flame stays large, yellow and sooty even after adjusting the air shutter?
Possible problem with the gas regulator allowing too much gas through the system. On LP systems the regulator should be on the storage tank. The regulator on the range usually has a changeable cap and plunger. One direction is for LP and the other direction is NAT gas. In the LP position, the plunger actually holds the range regulator wide open letting the one on the storage tank do the job.
May 02, 2015 | Kitchen Ranges
Why does the oven burner seem to be getting too much gas?
I see to have too much gas pressure after converting my Neptune dryer from natural gas to LP
you should not try to adjust the flame. LP burns more yellow that NG. The gas pressure automatically regulates the airflow based on the dynamic pressure that goes through the burner chamber. If your flame is roaring and pushing forward, everything is Okay, if it is a "Lazy" and falling flame, you have a blockage of the airflow - venting system
Mar 03, 2014 | Maytag Neptune MDG5500AW Gas Dryer
It does not appear that we are getting enough gas to the burners only the right side is lighting have made all the adjustments suggested in the manuel. Is a regulator required if you have a regulator at...
You need no regulator since you have one on the LP tank! You could have a bad LP regulator since you are not getting gas to the other burners!
Sep 03, 2011 | DCS BGB48BQRLP
How do you adjust lp gas regulator
LP gas regulators are sealed units, no adjustment.
Jun 27, 2010 | Char-Broil CharBroil 4637318 Grill
How do i know when to change my reserve lpg gas bottle when i am using an automatic changeover valve?
replace the first cylinder when the indicator shows red the regulator will "automatically" change.
May 29, 2010 | Grilling
Converting from lp gas to natural gas
just the orifices will do, the bake and broilerahve an adjustable hood thatwill need to be tightened down as well as an adjustment made to the regulator(needs brass nut flipped from nat. to lp.)
Mar 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Switching from natural to lp gas
Hi, The gas jet is too large and the gas valve needs adapted for lp gas. Lp gas has more pressure so the jets are smaller. Any appliance parts store should have the kit needed to adapt the gas valve along with the jet. The valve pressure will also need to be adjusted using a cheap water column gage also available at the appliance parts store. Check with them on what the pressure needs to be in your area. If the regulator is part of the lp it should be set right. If it is part of the fryer, set up for natural gas, and there is no lp regulator, it will need to be adjusted and or replaced with an lp regulator. Gas companies are usually very helpful with such things because they are concerned about gas safety. Good luck.
Sep 23, 2006 | Cecilware GF-28 Deep Fryer
Maytag MGS5870 Gas Kitchen Range Logo
23 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
