Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
What are the specs for the Honda engine that runs my 5500 watt Northstar Generator
  • 384 Answers
SOURCE: There is absolutely no voltage output. What
My generator has a switch to turn on the output, you must turn it "ON" to get power.
Posted on Jun 11, 2009
  • 384 Answers
SOURCE: Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Posted on Jul 01, 2009
deme-tri
  • 90 Answers
SOURCE: New NorthStar generator with Honda GX620 runs only a few seconds.
caborator needs cleaning
Posted on Aug 02, 2009
SOURCE: Honda 5500 Generator
If you have checked the stator, rotor and brushes and they appear alright then it is probably a voltage regulator. The honda dealer can run a test and confirm the problem at very little expense. It cost me 25 dollars Canadian to preform the test and it was well worth the money because you cannot return electrical parts and they can be very expensive. Have a great day!
davedulmage@sympatico.ca
Posted on Aug 14, 2009
harlan301
  • 205 Answers
SOURCE: how to flash field north star 5500 generator
wire a 120v 15a to 9vdc or 12vdc battery make sure you have no voltage out of the 240 side. with the unit running plug into the 120v receptacl QUICKLY pull out. check power out put. if it did'nt work check your battery, than do it again twice as long. you must check all component before doing this to make sure you don't have any other fail-er. this is danger-us be careful. good luck
Posted on Oct 13, 2009
Northstar 5500 watt generator lost power to outlets and is squealing loud at the generator side of unit, there is no switch for output
squealing either bearing,bushing or winding going or gone if bushings or bearings might be able to repair if not to damaged
Aug 29, 2016 | Northstar Electrical Supplies
Northstar 5500. Voltage good. sounds and runs good. But, makes bad noise from gen head area when under any load. I replaced the bearing. Anything else?
Stator is contacting the rotor, did you replace both bearings? remove the stator and look for damage on the stator and rotor laminates
Feb 26, 2015 | Northstar 5500/4500 Watt CARB Compliant...
How much output can i get from northstar 5500 ppg generator
there are two things in generator out put
one is max out put which is 5500 in your case and another is rated out put which should be about 4500 in your generator Max out put should be used only for a little time say half an hour otherwise generator is suppose to run on rated load or rated out put which is 4.5 kva or 4500watts in your set that also when you are in Ideal conditions means if you are at the sea level if you are above in altitude you can calculate that engine will loose its efficiency at the rate of 3% after every 1000 feet altitude inthat way you can calculate how much rated load you can put on the generator
Jun 30, 2012 | Northstar Generator 9 Hp, 5500 Watt,...
Generator runs fine- does not produce any power- checked breakers all ok
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
Aug 31, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
How to flash field north star 5500 generator
Oct 08, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Aug 13, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Jun 10, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
