Question about Bakers Pride Y-600 Gas Single Oven
Bakers pride commercial oven flames turn on and then turns off won't stay lit
2 Suggested Answers
  • 125 Answers
SOURCE: bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Posted on Feb 22, 2009
Put in new valve and thermal couple but pilot stays lit , but when thermostat is turned on everything blows out after a few minutes
Check your exhaust does the flame on the burner look like it is starting to float after a few minutes if so you are starving for secondary air
Feb 01, 2014 | Bakers Pride Y-600 Gas Single Oven
My oven when i close the flame goes off
If the oven will light and work with the door open but flames out with the door closed, you have the air input blocked somehow. I know some people line their ovens with aluminum foil, but you have to make sure that you have the air flow.
Jun 03, 2011 | Bakers Pride BAK-DS805 Gas Single Oven
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Bakers pride pizza oven not lighting
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Too hot
Hi, not sure if you ever received a reply, but there is a setting known as "bypass" on commercial thermostats, if you took the cover off to replace it, you can access this screw, it is part of the body of the thermostat, either to the left or the right of the knob shaft, usually has a "B" stamped, or molded into the body. What this setting does is when the thermostat reaches temperature, it would normally close, shutting off the supply to the burner, thus the temp would begin to fall, by the time it opened back up, the temp would have fallen too much, causing a large temp swing. The bypass setting opens or shuts a passage that "bypasses" the thermostat main valve, keeping just a little burner, making the swing, or fluctuation smaller. So, you probably have a setting too big, causing your bypass flame to be too big, raising, or keeping the temp too high, try turning it in (cw) to lower it slightly, a small turn makes a huge difference, so go easy. Hope that helps, and thank you.
May 08, 2008 | Bakers Pride Y-600 Gas Single Oven
Bakers Pride Y-600 Gas Single Oven Logo
139 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
Paul Carew
Dan Webster
Dan Webster
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
