Question about Maytag Washing Machines
Lid lock flashing kicking in and out will not start
Bravos mvwx500xl1
5 Suggested Answers
  • 113 Answers
SOURCE: maytag bravos
You have a broken lid switch, get me the model # and ill post a schematic and part #, thanks Dave www.washermd.com
Posted on Dec 17, 2008
  • 220 Answers
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Posted on Sep 01, 2009
caroldon
  • 17130 Answers
SOURCE: brand new Whirlpool WTW4800XQ out
Before you attempt to do anything please check if the drum lock is removed, check the power plug, connect the water line inlet. and finally check the settings of the program.
Read through the manual and DO NOT ATTEMPT TO DO ANY REPAIR AS BEING A NEW SET you have warranty.
Call your dealer if the set hums even after the initial checks were done.
Posted on Aug 04, 2011
richroth
  • 9472 Answers
SOURCE: maytag bravo lid was stuck in a locked position and is now not locking at all
What is the model number of the unit?
Posted on Nov 14, 2012
My Maytag bravos will not start at first the lid lock light was flashing I got the codes for the washer and all error codes are the lid lock assembly.still having same error codes
if your sure its the codes for the lid lock your getting I hope you have replaced them (do make sure to align pin on front right side ) , as ive had two of these now that have codes for the tray lock that's the tray at the back of lid area it needs to be back and latched tight to run past wash step , due to these being plastic and the water entering drum just behind them I suspect the hot water to messing with there latch mech and not allowing 4 a complete latch or something , anyways I have just replaced them to eliminate the fault in the past that's how I found out about the lid pin holes being slotted to allow for placement
Dec 19, 2016 | Maytag Washing Machines
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Washing Machines Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
