Question about Acer PH110 Multimedia Projector
How do I unlock my Acer projector without the key
How do I get my projector to allow me full access to the system without a key to unlock it
2 Suggested Answers
nishantraj88
  • 98 Answers
SOURCE: acer aspire 1310 "F2"-Key does only
MOSTLY BRANDED COMPANIES LOCK THE BIOS AND U PROBABLY DONT HAVE A CHANCE TO GET FULL ACCESS.
Posted on Sep 02, 2011
How can I unlock the function keys without the remote control?
Hi
How to Release the System Lock
Turn on the power. If the system lock is applied, the system-resetting screen appears. Press the following keys in this
order.
MENU ? ENTER ? ENTER ? MENU ? UNDO ? UNDO ? MENU
After pressing the MENU key first, press the remaining six keys within 10 seconds.
Mar 19, 2016 | Sharp Notevision PG-M20X Multimedia...
How does the ignition interlock work on the mazda mpv 2003 ? I can't start the car without the remote control : Simply turning the key will not even crank, does nothing.
Often, you need to press the unlock button on the remote twice. First press unlocks the door and second press disables the immobiliser and allows the vehicle to start. The key alone will not start the vehicle.
Alternatively, when the key is in the ignition - press the remote unlock again.
The remote acts as an immobiliser device. The reason your car won't start on the key is probably because the system won't allow any key in the ignition - it is preventing theft of the vehicle. Once the unlock button on the remote is pressed the system then recognises that key is the legitimate one for the vehicle and the disables the immobiliser and allows you to start the car
Feb 19, 2016 | Mazda Cars & Trucks
Unlock keypad
I made the same mistake. The solution was to update the firmware. After the update, all settings were set to default---including enabling the projector's keypad.
Apr 17, 2013 | InFocus In122 Svga Projector - IN122
Door keys will not insert all the way
if you use the central locking all the time the lockes get clogged you need to spray loads and loads off wd40 or other brands in the key hole to flush out the lockes. and then the pins will move so the key will go in.
Jul 13, 2017 | 1990 Lexus ES 250
How to reset sony projector vpl-es2 without remote control cause the panel key is lock?
Turn the projector on and leave in standby mode. To do this press the power on button for 10 seconds until the projector comes on.
To unlock the main panel keys, press the MENU button for 10 seconds.
Aug 05, 2011 | Sony VPL-CS7 Multimedia Projector
Trying to setup the Panasonic PTL 720U, accidentally turned off the control key to OFF in the menu and now cannot access Menu or another other options. How do I reset back to factory or so I can access the...
In order to set the CONTROL KEY to "ON" without
using the remote control unit, keep holding down
the ENTER button on the projector and press the
MENU button for more than 2 seconds. It will then
be turned ON.
Feb 12, 2011 | Panasonic PT L720U Multimedia Projector
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
In a powewr point presentation, my laptop screen goes black when a connect the vga cable to the projector
That's normal. If you want to see the PPT on both screens, press the "fn" key and another key that has either two little monitor icons or "CRT/LCD" on it. Each time you press the keys (at the same time), the output will cycle thru laptop LCD only, projector only, both, etc.
Some systems require you to have the projector attached and running to auto detect. Some don't. But all allow for the "fn" and LCD key adjustment.
Nov 12, 2009 | Microsoft Office SharePoint Server 2007...
Keys mounted on projector got locked accidently
With System-Lock input window onscreen, press the "MENU", "ENTER", "ENTER", "MENU", "ENTER", "ENTER" and "MENU" keys, in this order,
on the remote controller.
Jun 17, 2009 | Sharp XR-30S Projector
Acer PH110 Multimedia Projector Logo
41 people viewed this question
Top Acer Office Equipment & Supplies Experts
Electro Med Services...
meteshadow
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
