Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
How to clean a scotsman icemaker - Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
    Sergeant:
  • 107 Answers
I think it may depend on the type that you have. Do you have a commercial ice machine? My family does because we have a large family. I make sure that it is cleaned a few times a year so that it stays good. We get someone to do it for us though. Have you considered that? Commercial Ice Machines in Largo FL
Posted on Aug 27, 2015
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
WHAT SHOULDN'T BE DONE.
Never keep anything in the ice storage bin that is not ice; objects like wine or beer bottles are not only unsanitary, but the labels may slip off and plug up the drain. Never allow the machine to operate without regular. The machine will last longer if it is kept clean. Regular cleaning should happen at least once per year,and preferable twice. Some water conditions will dictate even more frequent cleaning of the ice making section, and some carpets or pets will dictate more frequent cleaning or the condenser.
WHAT SHOULD BE KEPT CLEAN?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
HOW TO CLEAN THE CABINET.
Wipe off any spills on the surface of the door and handle as they occur. If anything spilled on the door of gasket dries onto the surface, wash with soap and warm water to remove.
HOW TO CLEAN THE ICE STORAGE BIN.
The ice storage bin should be sanitized occasionally. It is usually convenient to sanitize the bin after the ice making system has been cleaned, and the storage bin empty. A sanitizing solution can be made of 1 ounce of household bleach and two gallons of hot (95 deg F.-115 deg F.)Water. Use a clean cloth and wipe down the interior of the ice storage bin with the sanitizing solution, pour some of the solution down the drain. Allow to dry.
HOW TO CLEAN THE CONDENSER.
The condenser is like a radiator on a car, it has fins and tubed that can become clogged. To clean:
1. Remove the kick plate.
2. Locate the condenser surface.
3. Vacuum the surface, remove all dust and lint.
4. Replace the kick plate.
CLEANING THE SYSTEM.
HOW TO CLEAN THE ICE MAKING SYSTEM.
1. Open the door and turn the ice machine control knob off.
2. Scoop out all of the ice, either discard it or save it in a ice chest or cooler.
3. Pour 4 ounces of Scotsman ice Machine Cleaner ( available from a local Scotsman Distributor or Dealer, ask for part number 19-0343-06- an 8 ounce bottle) into the ice machine reservoir.
4. Turn the ice machine control to ON.
5. Allow the machine to operate for about 2 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off of the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin interior.
10. Replace the ice removed in step 2.
The ice scoop should be washed regularly, wash it just like any other food container.
WARNING; Scotsman ice machine cleaner contains acids. These compounds may cause burns. If swallowed,DO NOT induce vomiting. Give large amounts of water or milk. Call Physician immediately. In case of skin contact,flush with water. Keep out of the reach of children. Always follow manufactures directions.
Posted on Nov 17, 2014
SCOTSMAN ICEMAKER ICE SLAB NOT DROPPING DOWN TOO GRID
WHEN WAS THE LAST TIME THE EVAPORATOR WAS DESCALED? WHEN IT GOES INTO HARVSET DOES THE EVAP PLATE THAW OUT OR STAYS FROZEN?
Jan 05, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman cm250ae-1c making very wet ice
It might be a dirty or damaged ice tray. When in the harvest mode the hot gas will be directed through the tray untill the cubes fall tripping the reset to start the freezing cycle again. If the cubes are sticking because of rust or scale buildup the cubes get "overmelted" causing the "wet cubes".CAREFULLY clean the ice tray . Use vinegar or ice machine cleaner do not use any cleaning pads steel wool or sand paper as this will ruin ice tray. Also make sure icemaker is level both ways. Hope this helps.
Dec 27, 2013 | Refrigerators
I have a Scotsman SCN60 nugget icemaker and when I add cleaning solution to reservoir it just stays there
Hi, Are you using Scotsman ice machine cleaner? and are you using the right amount?
1. Open the door and turn the ice machine control knob to off.
2. Scoop out all the ice, discard it.
3. Pour 4 ounces of Scotsman ice machine cleaner into the ice machine reservoir.
4. Turn the ice machine control to on.
5. Allow the machine to operate for about 2 to 3 hours.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off the liner.
9. Sanitize the bin liner.
Now a dirty evaporator plate will not stop it from making ice it will cause it to hang up on the plate during harvest cycle if machine is not making ice good then there is something else wrong but when you clean the machine also make sure you clean the condenser coil and fan if this is dirty this will cause it to slow down on production of ice.
Dec 19, 2013 | Scotsman DCE33PA1BC 15in Built-in...
We have four Scotsman Ice Makers. The curtains are beginning to turn a little green. What is the approximate cost of replacing these curtains. How much per curtain?
Unless they are terrible you can clean the curtains. What you do is put icemaker cleaner in the icemaker and run it through a cycle. I don't know how much the curtains cost.
Sep 28, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
May 23, 2010 | Scotsman Ice Machine - 290lb...
Bin Full light stays on all the time
This is usually an indication that the photo eyes are probably dirty. They "See" across the opening where the ice drops through. If they are dirty, it registers as a fill machine.
A bin stat can cause the same problem.
The eyes and sometimes be a major problem finding them getting to them. On smaller machines like this one, it's hard to get your hands on them.
Good Luck and hope this helps.
Jan 08, 2009 | Scotsman Freezer Clear Icemaker w/ Pump
Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Aug 05, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Water keeps running in scotsman icemaker
Check for trash in the water valve. Insure the water lines don't have rust flakes in them. The water valve is operated by the float arm. Anything in the water line can keep the valve stuck open and stop production of ice. Hope this helps, Sea Breeze
Oct 28, 2007 | Scotsman Cooled Modular Contour Cuber...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
371 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
