Question about Drive Medical Winnie Walker, Mimi Lite Push Brake Rollator
How do you adjust the brakes on a 3 wheel walker from drive????
How to adjust brakes
Hi.can you tell me how to ajust front calipers on BA Falcon on 2003 6 cyl. thanks.
Jan 01, 2014 | Drive Medical Winnie Walker, Mimi Lite...
How to adjust parking brake on winnie lite 3 wheel rollator
For openers "LOCKING" handles)...
Very GENTLY would be the first caution..
Unlike the brakes on those long ago bicycles we used to have... these WALKER BRAKES are pretty cheesy plastic...
None of the ones I've been compelled to work with have
interchangeable parts... SO BE GENTLE.
Look at both ends of the cable of the first wheel you want to adjust...
You are looking for a threaded sleeve with a nut on it...
If the brakes are too tight you will want to shorten the sleeve...
Too loose you will want to lengthen it (tightening the cable).
DO NOT overtighten...
These are all plastic... cheaply constructed... but EXPENSIVE to replace.
I have had to hand craft REPLACEMENT PARTS to repair these things (nothing is STANDARD (but the careless attitudes).
When you do break'em... AMAZON had the greatest selection...
(knowing the mounting diameter, and cable length is imperative
(sold in PAIRS)).
Carnac the Magnificent
Jun 20, 2012 | Drive Winnie Lite Supreme 3 Wheel Rollator...
Adjusting the parking brake on a MiTSubichi ENDEAVOUR 2005
If your parking brake is too loose or is not properly adjusted, you may encounter problems while parking, positioning and driving your car. Most of the time, car owners would send their car to a mechanic in order to fix and tighten the parking brake. However, you can actually skip this step and adjust your parking brake yourself. When your car starts to slip on a hill in its park position, you need to start tightening the parking brake.1 Remove the car's center console cover placed around your parking brake level inside your car. This is found between the seat of the driver and the front passenger.2 Use your wrench to turn its adjuster nut found at the end of your parking brake's cable rod. Loosen the adjuster nut with your wrench, while making sure that it does not come off at your parking brake cable rod's end.3 Raise your car rear wheels using your jack, and use your jack stands to support both its rear wheels.4 Pull up your parking brake handle up to two clicks or notches. Tighten your adjuster nut until you feel a slight resistance on your rear wheels whenever you spin them.5 Release your parking brake lever. Check and make sure that your rear wheels are still able to spin freely and without any resistance.6 Pull up on your parking brake lever up to three to five clicks or notches, while making sure that your car's rear wheels are not turning at all.7 Lower the car by adjusting your jack, and remove your jack stands from your car's rear wheels.
Oct 03, 2011 | 2005 Mitsubishi Endeavor
Brakes will not lock in parking position
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. This same adjustment technique applies when you pull the handles down in the park position and when you squeeze them to slow down. Hope this helps.
Nov 22, 2010 | Drive Medical Winnie Walker, Mimi Lite...
The brakes on a clever lite rolling walker will not engage when the grips are squeezed
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. Hope this helps.
Nov 09, 2010 | Drive Medical Winnie Walker, Mimi Lite...
What are the advantages to having a 4 wheel knee walker versus a 3 wheel knee walker
the 4 wheelers are generally more stable, the three wheelers are more manouvrable
Sep 02, 2010 | Clarity Knee Walker Leg Scooter Ankle...
Need to adjust the brakes on a Winnie Walker Lite Deluxe walker.
Please try :Instruction Manuals.Visit :-www.FixYa.com/Instruction+Manuals
May 12, 2010 | Drive Medical Winnie Walker, Mimi Lite...
I need a diagram for the rear drum brake for 2002 Ford Ranger
Copy and paste this into your search window: 2002 ford ranger rear brake diagram
You should see four pictures pop up, select the brake parts diagram or the brake picture.
Sep 03, 2009 | 1993 Ford F150 SuperCab
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Drive Medical Winnie Walker, Mimi Lite Push Brake Rollator Logo
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
