Question about Acer Office Equipment & Supplies
How to unlock my acer projector
My Acer projector has a insert in the back with an insignia of a deadbolt. I need to unlock the system and cannot do so without a certain key made for the specific brand of Acer.
marsrover
  • 682 Answers
SOURCE: Acer XD1250P DLP Projector
please switch your laptop on first and then your video projector and try fn/f5 orf6 orf7
Posted on Jun 17, 2008
SOURCE: acer projector
My Acer PD125projector was working perfectly but has been out of use for 6 months. When I connect it now, I get:- 1. "ACER - Empowering People" screen, then 2. After a short delay the message "The Lamp is approaching the end of its useful life at full power ........." is displayed for a short time, then 3. The initial screen returns, together with a "No Signal" message. After this warm up none of the controls on the actual machine nor the the remote controller, except for the power button, will do anything. What can I do about this?
Posted on Aug 11, 2008
SOURCE: no data from laptop to projector
I could not use mine either, I had to use the s video cable.
Posted on Nov 20, 2008
mastertech48
  • 149 Answers
SOURCE: how achieve maximum resolution acer projector
When you connect a source to the projector, the unit will match the resolution input to it. As long as you don't exceed the max resolution, which is considerable, the unit will display it. Go into the menu and select auto-image to have the projector give you the best quality image. Hope I helped you!---Rick
Posted on Sep 09, 2009
SOURCE: No signal or loses signal from computer
i have same problem so,if you have solution to your problem pls. mail me at yourkumargaurav@gmail.com
thanx.
Posted on Sep 10, 2012
I just installed a Schlage deadbolt. If I lock it from the outside (using the key) it locks fine, but I can't remove the key without unlocking it. Now What?
Hi Winston:
Is it possible to try this:
- pull the lock from the door while leaving the deadbolt in place
- turn the mechanism 180 degrees.
- re-install and give it a try.
Let me know how you progress.
Jun 21, 2015 | Schlage Locks & Locksmithing
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
Why won't my schlage deadbolt key go to the neutral spot in the lock position to remove the key?
You likely have the lever that goes from the outside portion of the lock through the striker/bolt assembly into the inside portion rotated into an incorrect position when you insert it into the striker/bolt assembly.
Sep 18, 2014 | Locks & Locksmithing
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
Jan 05, 2014 | Kwikset Locks & Locksmithing
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
Dec 01, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
How to unlock administrative password on acer laptop
I also forgot my Acer windows password last week.
I searched the solutions on the internet, at last I unlock administrative password with a tool called Windows Password Reset.
It just spent me 5 minutes to reset admin password.I found this usefull, you also can have a try.
Jun 10, 2012 | Acer Aspire 3502WLCi Notebook
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Deadbolt wont unlock
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Jan 09, 2010 | Kwikset Brz Sgl Cyl Deadbolt
Insignia NS PDVD8 Rgion unlock codes
I found a fix to my problem. This worked for me.
1) Power On.
2) Without a disc inside of the DVD player and using the remote control, press the setup button.
3) Press the right key on the remote 3 times and the preference page will appear.
4) Press 9653.
5) Use the up and down keys to select the Region.
6) Select 0 for all regions. 0 might look like a box.
7) Press the enter button.
8) Insert DVD.
9) If it works for you, then you're very welcome.
Dec 09, 2007 | Insignia NS-8PDVD
262 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
