Question about DeLonghi Heating & Cooling
Fan won t change speeds - DeLonghi Heating & Cooling
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
1996 ford probe is overheating, the fan won't come on
You have one of these:
- Blown fan Fusible
- Blown fan Motor
- Water temp sensor is shot
i won't say Blown headgasket or too low coolant level on the system because you have the fan not starting at all. that the root of the problem, do your engine overheats at high speeds? highway?
Dec 20, 2012 | 1996 Ford Probe
Model 6k890 motor
Will the fan run with the fan switch in the ON position? as opposed to the AUTO position. If so the temperature or time delay or motor may be bad.
the fan switch operates the fan relay that controls high/cooling speed, heat speed is a time or temp delay.
Oct 25, 2012 | Dayton Gas Furnace Heater
2004 jeep grand Cherokee's radiator fan won't run on high
Hi Al, I'm glad to help!
Three possible causes: (1) The high speed circuit in the radiator fan motor could be defective. (2) The high speed fan relay Could be defective. (3) It possibly may have a wiring issue. I've seen at times where you can wiggle the fan motor connector that's mounted on the fan shroud and the motor will kick on. If this is the case then replace the hole assembly which is a motor and shroud assembly. Hope this helps and have an awesome day.
Aug 24, 2012 | Cars & Trucks
Why won't my air conditioner change fan speeds
Having same problem...ac unit seems not to be changing fan speed and cooling level has been reduced ????
I have no solution. but we have just run into the 7 day of 95+ degrees with high humidity. do not believe the units have frozen up, just seems that the fan is in low speed mode and trying to raise it to F2 or F3 doesn't seem to help.??? Most of the time we have to increase temperature because its too cold ?? now it doesnt seem to be cooling the same ??? I await anyones solution.
Aug 06, 2012 | Kenmore 75121 Thru-Wall/Window Air...
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
06 silverado blower fan won`t shut off finally killed battery
The connection at the blower resistor on these model years had problems with poor connections.
The increased resistance on the terminals caused them to heat up and burn. Some would go open circuit and not work at all and some would short to ground and run all the time, like yours.
As you have already discovered, you will need to replace the pieces.
Nov 01, 2009 | 2006 Chevrolet Silverado 1500 2WD
Heating & Cooling Logo
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
