Question about Leviton R03-5634-A Two Single-pole Switches
How to wire a leviton 5634 for agarbage disposal
    Habit-Forming:
  • 135 Answers
If you are replacing an existing switch, either replace one wire at a time, or write down the wire colors from the old switch.
or look here: http://www.leviton.com/OA_HTML/LevitonSearchResults.jsp?kw=5634+wiring+diagram&tbon=D
Posted on Aug 08, 2014
2 Suggested Answers
SOURCE: how to connect leviton 5634 from GFI
GFCI device is not identified.
Leviton 5634 is typical double switch.
Open following link for image showing double switch connected to typical GFCI outlet.
http://waterheatertimer.org/How-to-wire-GFCI.html
Add a comment with details about your wiring and GFCI for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jun 10, 2011
I have a leviton double switch that i can't get to work. I have 3 white and 3 black in the box
Try the link below for a diagram.
I would think that you have one black feed and two black legs going out, and three common wires that should be wired together with a wire nut. Is this for a ceiling fan with a light? or ?
May 14, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
Light switch
Try to switch the white with the black wire
Apr 16, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
Older house has 1 neutral wire and one hot wire. How do I replace new outle
Ok, first things first, you want to use the terminals on either side of the outlet, connect black to one side and white to the other. The reason there are two screws per side is to allow you to run a wire to the next outlet in line if you choose to do so. On the outlets with two white wires running in, using a voltmeter confirm that you have 120v between the two wires, if this is the case then just connect as though one were black. Hope this helps
Jan 31, 2012 | Leviton 5634 Dual 1 Pole Switch Decora...
How to connect leviton 5634 from GFI
Upvote the help.
Jun 09, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
Trying to install this thing, and having a slight issue. I've got a white, black and red line power line in the bathroom, obviously.. I've also got a dual switch Leviton 5634 which I'm just trying to...
I assume these three wires are coming to the switch box via from the light/fan unit and the light/fan unit has a box with 5 wires in it, including a white and black from the electric panel, and that the neutral is not routed to your switch box. I think your mistake is assuming that the black wire in the switch box is the hot wire, but it is actually the red or the white. Try switching the wires on your switch so that the red is common, If that doesn't work, try the white as common. Or you might open the box where the fan is, and confirm which of your three wires is connected to the hot black wire. Please vote if you found this helpful.
Good luck, Al K
Feb 24, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
Hi...do I run the exposed copper wire between the two poles on the left hand side of the switch....e.g. the middle screw and the bottom screw.? Thanks
No there are two screws that are tied together on the right side that is the side the hot wire ties to. The other side that has two screws one at the top and one at the bottom. This is the screws that the wires from the lights will go to
Sep 05, 2010 | Leviton 5634 Dual 1 Pole Switch Decora...
How do I wire for 2 seperat lights on a commom system?
{SW1}---Light 1 switched leg to fixture 1
HOT wire (Line or Feed)----{
{SW2}---Light 2 switched leg to fixture 2
The wire supplying power to the switches will be connected to the "LINE" terminals tied together with a breakaway tab (common feed). The upper "LOAD" side terminal will output to the first light and the lower "LOAD" side terminal will output to the second light. The neutral (White) wires if present will be joined together (wirenut).
All electrical work should only be done by qualified individuals.
Apr 12, 2010 | Leviton 5634 Dual 1 Pole Switch Decora...
I am replacing a single pole switch that contains two rockers - one controls some lights, the other the garbage disposal. I am using a Levitron 5634; when I removed the broken switch it had 3 wires...
You have the hot wire on the wrong side of the switch. The side of the switch with the fin is where you put the hot wire. On the other side of the switch where there is no fin is where you put the other two wires one on each screw. When you have it wired that wat your switch will work like the old one. Also if you would like the lights to come on with the top part of switch. But works with the bottom switch you just need to switch the two wires from top to bottom.
Jan 20, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
Need wiring diagram for 110v outlet: one switched, one always hot
found a wiring diagram online. Realized the hot tab had to be broken (not the neutral tab).
Apr 10, 2009 | Leviton 5634 Dual 1 Pole Switch Decora...
Leviton R03-5634-A Two Single-pole Switches Logo
106 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
