Outside unit wont come on, doesnt have manufacturer name on it
Would like to trouble shoot myself, I have info, seriel# ect..
    Sergeant:
  • 340 Answers
That would be a pay for question. unless you have the proper tools experience with electricity ya can make more trouble for your self than you want and could make the news call a qualified service co. Tom
Posted on Jun 23, 2009
My nextech wireless weather forcaster wont display out side temp. I have replaced the bats and held down the down arrow button
I dont have this unit but you might look for a reset button inside the battery compartment (or on the back, some times labeled).
Also, standard procedures are, remove batts. for a few minutes and follow the manuals instructions to start it up. Look for manual on internet. Also check for trouble shooting tips at manufactures web site.
You tested the "new" batteries, right? Long shot is leave batteries out over night to be sure unit is off. Try to find a reset button in manual or manufactures web site. Think about opening unit up with screw driver and look for reset. Did you follow instructions to select channel on both inside and outside units? My Weather Station has 3 chanels and I have to match them.
Nov 21, 2016 | Measuring Tools & Sensors
Manual
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals on the site.
Apr 23, 2012 | Computers & Internet
Car wont start, saying code p0116 on a 2006 dodge caravan
this obd2 trouble code table can help you understand the meaning of code.
and for this code, you can try,
If there are any other ECT sensor codes, diagnose them first.
Using a scan tool, check the ECT reading. On a cold engine, it should match the IAT reading or should be equal to ambient (outside) temperature reading. If it does match the IAT or ambient temp, check the freeze frame data on your scan tool (if equipped). The saved data should tell you what the ECT reading was when the fault occurred.
a) If the saved info indicates that the engine coolant reading was at the coldest exreme (around -30 deg. F) then that's a good indication the ECT resistance was intermittently high (unless you live in Anchorage!) Check for an open in the ECT sensor ground and signal circuits and repair as necessary. If they appear okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
b) If the saved info indicates that the engine coolant reading was at the warmest exreme (around 250+ deg.F) then that's a good indication the ECT resistance was intermittently low. Check for a short to ground on the signal circuit and repair as necessary. If it appears okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
Sep 09, 2011 | 2006 Dodge Grand Caravan
34000 btu, outside condenser unit keeps tripping breaker. Unit was manufactured 02-20-2005
Hi, It is tripping the breaker because the compressor is locked up and will not start..
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 11, 2010 | Haier Heating & Cooling
Heat pump trouble shooting fema trailor i have a az75h18dacm1 self contained air cooled heat pump that wont work. cant find any info on this unit. have replaced the stat,the fan comes on only if it want's...
Normally the Fan only comes on when it is called for by the compressor, here is their web page that you can go to and pick your model and get their trouble shooting guide to repair your system, they also have a 800 phone number to help you. I am familiar with the unit but you need to look in there trouble shooting guide to properly troubleshoot your problem, you can call there 800 number and ask for help as well. Hope this helps.
http://www.rheem.com/Products/Heating_and_Cooling/
Mar 01, 2010 | Heating & Cooling
What is the tonnage of model # ce60-1fb,also manufacture date?
That is a 5ton condensing unit.(12k btu per ton).If the manufacture date is'nt on the outside of unit,you should be able to find it as well as serial ect.....On the inside of the service panel.
Jan 06, 2010 | Goodman Heating & Cooling
Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Nov 02, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Wont turn on
Normally there are steps to trouble shoot the problem. If you did not find anything useful such as the following suggestions to trouble shoot the problem then please visit the manufacturers information below, based upon the product information you have posted on here.
Let us know how things work out. Also, sorry to see no one has gotten back to you sooner!
Trouble shoot:
Take out batteries for a full minute then insert back in, try to restart. some times that resets it otherwise press the rest button on the device.
Check with the manufacturer for a possible firmware upgrade that might need to be installed in order to get this working or to see if this is a defective unit.
USB-Stick MP3 Player (1GB) Documentation
Feb 26, 2008 | Coby MP-C883 MP3 Player
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
