Question about U-Line Refrigerators
How uline h-1649 error 4 - U-Line Refrigerators
HELLO I HAVE A ULINE WH95TP IN A BOAT WE HAVE IN FOR REPAIR AND THE ICEMAKER WONT GET COLD WAS WORKING BEFORE ANY THOUGHTS ON WHAT TO CHECK THERE ARE NO SCHAMADICS ON IT THANKS JOHN
Ice makers need refrigerant just like freezers and if it get too low it will quit working and probably burn itself out .call a refrigeration repair person and ask them to check it out .
Jul 30, 2015 | ULINE U Line Marine/rv Ice Makers Wh95tp...
Where can I purchase 4 oz, 6 oz and 8 oz clear glass jars with cork closures for bath salts?
http://www.uline.com/Product/AdvSearchResult.aspx?keywords=4+oz+glass+bottles&pricode=WZ500&AdKeyword=4%20oz%20glass%20bottles&AdMatchtype=p&gclid=CPGq_5L5jcMCFWgF7AodM0cAxQ&gclsrc=aw.ds Uline
Jan 12, 2015 | Blenders
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
I have a URC60231 Universal Remote Control. Please can you give me the 4 digit code to operate my Samsung P2270HD LCD TV. Many Thanks Lex
Remote control TV Set-up codes
code for Samsung
0648 0617 0208 0067 0586 1279 1660 0123 0674 1265 0039 0247 0512 0400 0090 1937 0294 0246 0062 0102 0238 0712 0549 0193 0655 0842 1342 1614 1649 0796 0844 1662 1488 1708
May 27, 2011 | Televison & Video
Tv neo tv 2121tx
trebami kod za otkljucqavanje neotv-2121tx
Jan 17, 2010 | Televison & Video
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Mar 18, 2009 | U-Line Uline Origins Series...
My uline drawer fridge quit working. Who should I call to fix it?
I would call Uline directly and allow them to recommend someone in your area that does warranty work for Uline. In this fashion, you are assured professional results and OEM parts....
Good Luck, Eric Campion
Feb 26, 2009 | U-Line 75R Refrigerator
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
Refrigerators Logo
35 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
