Question about Tools & Hardware - Others
Can a regular magnet get stronger than an electro-magnet in a very cold temperature?
How to get a spark plug out on a 2007 ford f150 that the outer shell has separated from the porcelain of the spark plug the plug has not broke just the threaded part has come out
magnet should be able to remover it, industrial type as they are stronger, you can get them from out of a honeywell cat flap. inside the cat collar part, or try a magnetic inspection stick, this should be able to get the spark plug out but you have to be gentle as it wont be a stronger magnet.
Aug 11, 2017 | Ford Cars & Trucks
Toyota wish.1.8...aircond not cold...gas ok..circuit ok relay ok...compressor ok..but still not cold....when turn on ac only blow air but not cold...tq need answer
Make sure the compressor is actually turning. Most auto compressors run a magnetic clutch drive. When the air con is turned on, an electro magnet pulls the compressor clutch in so instead of the pulley just idling, it turns the compressor as well. You normally hear a loud click when the clutch pulls in. If you have a close look, there is normally 1 wire coming out from the drive end of the compressor which is the feed wire for the electro magnetic clutch. Check if this has been disconnected or broken.
Sep 17, 2015 | MagnaFlow 2006 Toyota Matrix - 2WD, 1.8L...
Is it possible to adjust shower mixer temperature?
Now my best guess is that you kept heater too high for a long time which means that the pipe carrying hot and cold water got touched and water became hot So turn off the heater for while and let the pipes cool off then turn the heater on at a low setting ...
Aug 30, 2014 | Rubinet Home
Keurig "Add Water" problem. Reservoir magnet not strong enough?
It is at a point where I suggest you purchase a new one. Otherwise you will go thru a lot of agrivation.
Aug 10, 2014 | Keurig B60 Coffee Maker
2006 Lincoln Zephyr does not start when it gets cold out30 degrees F)
Where you at Kim,north pole,helping Santa,lol,How many cold cranking amps is your battery,may need a stronger one,Try this to see,remove battery overnight,store in your warm house,then in morning install back in car and see if it will start,if it does then battery is too weak for your Lincoln.Also metal shrinks in cold weather.
Dec 02, 2013 | 2006 Lincoln Zephyr
Water Dispenser Temperature Control/switch-off
Not on regular models. Most models have a water tank in the fridge compartment which makes the water temperature to stay just above freezing temperature.
Wanna a play with your unit. Then remove the tank and just add two pipe ends together. Eliminating the tank. Then you should get room temperature water after about 5 seconds of cold water. Be careful just connecting the two ends of pipe after removing tank might lead to freezing pipes if your fridge temperature is close to freezing temp.
Nov 26, 2013 | Samsung RF4287HA
I have a 1999 Chrysler Cirrus. I drove it yesterday with no problems at all. I go to start my car this morning and it wont start. Its turns over just fine it dont even sound like there is a problem but...
try the spare key in case its the chip in the key playing up for whatever reason if spare key doesnt work then check to see if the immobilisor light is on ,Now also of course if the temperature is too cold what can happen in extreme circumstances is a micro chip malfunction where they fail in the cold and if this is the case then push car into teh garage and let it warm up gently and it should start ,been getting this a lot with other things as well because of the cold and cheap chinese micro chips so your not the only one.Also keep car keys away from any electro magnetic source like tv screens and body scanners magnets and most of all a tesla induction battery charger ,be surprised how many people try to recharge their remote car keys on o0ne of these type of charger .
Feb 10, 2011 | Chrysler Cirrus Cars & Trucks
Why do some subs have a double stacked magnet
Think of the magnets on the sub as a engine, more magnets like an engine means more power, that relates to stronger push/pull on the speaker gainning more travel,quicker response,tighter more stable, cleaner bass, remember though that needs a better stronger amp to take advantage of all that speaker has to offer, have fun and good luck!
Nov 25, 2009 | JC Whitney - High-power Double-magnet...
2000 Nissan Altima temperature gauge and heater problem
sounds like you need to replace the thermostat.
Jan 29, 2009 | 2002 Nissan Altima
Tools & Hardware - Others Logo
43 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
