Question about Frigidaire 30" Freestanding Electric Range - White
What does F1 mean on Frigidaire model #316233850 oven does not work-burners do
We bought this used Frigidaire stove it worked before we got it home. We live in a mobile home. Replaced the 1980 Tappan range with Frigidaire 316233850. Plug on back of new stove did not match the plug in the wall. So, we bought a plug that matches the plug in the wall. Display shows code F1. Elements in oven do not work. Other than buying a used stove what have we done wrong. Thank you
  • Frigidaire
    Frigidaire May 17, 2014
    Good Afternoon Friend, I understand that you purchased a used Frigidaire range, which was working before you got it home. I see that you replaced the plug on it and plugged it in, and are now receiving an F1 error code, with neither the elements or oven working. . I will be more than happy to assist you. If I could please have the model number of your range, this way I can better assist you in resolving the possible troubles with your appliance. You will be able to find the model number either on the back of the door or in the bottom drawer, if there is one. Looking forward to hearing from you. WP
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
aborcass
  • 2651 Answers
SOURCE: Frigidaire electric range smooth top with no oven function
although you dont have hte model number , that is indeed a correct and valid part number for the control lists for a about $120. since your back there give a quick look at the wiring into the unit, is that ok ??? adn where the burnout is on the control does it appear to have shorted out against the back wall??? perhaps a relay on the board just blew??? i really wouldn't thinkn tha another component was goning to make that go bad, also ck the bake and broil elements for continuity, perhapa wire fell off the element blowing out the control
Posted on Mar 20, 2008
SOURCE: 1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Posted on Aug 02, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
The F1-2 error code appears on the range and the oven stops working but stove top burners still function?
Hi adsdunn2,
The F1:-2 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Aug 20, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire range/stove. I was roasting dinner at 300 then turn the oven up to 400 near the end. Shortly after there was a pop that sounded like it came from inside the oven. I thought a potato...
F1
  • The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Read more: Frigidaire Oven Error Codes ' eHow.com http://www.ehow.com/list_7105089_frigidaire-oven-error-codes.html#ixzz1OVfekgRx
Jun 06, 2011 | Frigidaire Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire 30" Freestanding Electric Range - White Logo
54 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
