Question about Toshiba SD-3960 DVD Player
Toshiba dvd player won't open
I cannot open my toshiba dvd player. it worked fine last night, but today when i tried to open it to remove the disc, it would not open.
  • 5 Answers
SOURCE: toshiba SD-K850 trouble
I contact Toshiba Service and they suggest to unplugg AC cord then wait for 3 minutes but this is not a real solution ("Bad" message). I already notice other Toshiba models have the same problems (SD-K750 & SD-3980), and they are replaced them because of component part failure. (my DVD is a SD-K850).
They also explain that if that process not work, I must call their
Service Dept. for more details, same phone # (1-800-631-3811).
Luck!
Posted on Nov 12, 2007
SOURCE: incorrect disc and bAd
I have the same problem, reads bad, won't play, took the top of a blow on it, alot, hoping dust would come off the lens, it did. Works now, also ran a disc cleaner in to after.
Have another dvd palyer, never had that problem, Philips.
Posted on Jan 09, 2008
jonniewalker
  • 1029 Answers
SOURCE: Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Posted on May 24, 2008
SOURCE: toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
Posted on Oct 07, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
Our Integra DPC 7.7 won't open
UNPLUG it then remove the cover and look for any disc(s)that may have become dislodged.
GL
Oct 29, 2012 | Integra Televison & Video
Dvd player trys to read disc but stops with a HO7 message, worked fine last night, but we did put a dvd in to watch but something came on the tv we wanted to watch and didn't turn off dvd
HELLO
This is a motor problem. Here is what to do to put it right.
Open the disc tray and switch off the power, then remove the lid off the player. Locate the disc motor and where the spindle goes through the motor put a little WD40 or light oil (but not too much) or it will get messy.
Turn the disc motor a few times yourself and let the lubricant soak in. Leave it for about 30 minutes then try it again - and it should work.
This works in a number of cases, though I can't guarantee it will work for you. TRY IT! (:-)
Oct 14, 2009 | Panasonic DVD-RV32 DVD Player
Won't play any DVDs
I mostly first always recommend a dvd lens cleaner to clean the lens incase there is something on the lens.
Is the player underwarranty? the lens may have a issue other than dirt and might need to be replaced.
What happened last time it worked fine? try unpluging the dvd player for 5 minutes and try again.
Jan 04, 2009 | Toshiba SD-6980 DVD Player
Presidian dvd recorder pdr 3222
Have had the same problem with my Presidian3222 for the last year, if I recorded something it would come back as invalid disc or blank disc or would not close disc out right, got so damn mad almost took a hammer to it last night, unplugged it like clicky said, did no good, thought cable co may have been sending single to screw up recording, but today took camcorder and tried to record something, same thing which seemed to let the cable co off the hook.
the following seemed to have fixed the problem, first open the player then unplug it, close the drawer 1/2 way, then I took compressed air and blew inside the player to clean the laser after that I have been able to record 3 movies and close the disc properly and finalize the disc properly, I even had 50 new disc made by sony that recorded kept saying were invalid, reads them fine now, I hope this helps everyone, because I was on the edge of putting this thing in the trash last night.
R.J.
Nov 26, 2007 | Dual Presidian DVD Recorder
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Even when the DVD is in the tray correctly, it says "No Disc"
I had a similar issue and now mine is opening closing opening and then powering off?
Mar 18, 2007 | Toshiba SDK615 Multi-disc DVD Player
Toshiba SD-3960 DVD Player Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
