Question about Toro Zero Turn Rider 74833 Lawn Mower Tractor Rider Ztr
My toro fh 580v smokes when i start it what is causing it to smoke?
My toro ztrn smokes when I stat it. it a white smoke is that the rings or something else? it's a fh 580v 19hp motor on a 52" deck
  • 739 Answers
Of course they (below) haven't mentioned that you may simply have carbon build up on your intake valve, which would allow normal oil from the head to drain into the cylinder. Before junking your mower, or doing a tear-down, I'd suggest a cleaning agent to remove the carbon from the valves first.
One thing I have done is during an oil change, replace the oil with kerosene and run until the engine is hot, drain it out, allow to cool, and then replace the oil. seems to remove carbon build up fairly effectively, and extends the life of your equipment.
Posted on Mar 23, 2015
  • 28 Answers
Hi.. your inlet valve stem seals are worn out, so oil will be drawn into the inlet with vacuum , as well as fuel...this is why it smokes on start up...quick fix , do an oil change but use a car oil like 15W40 weight oil
im sure you would be using a 10w30 oil now ,using a thicker oil might stop the smoke on start up, or it just wont smoke as much, regardless of using a thicker oil...the valve stems will still need to be replace.....good luck
Posted on Jun 07, 2014
5 Suggested Answers
SOURCE: I have a Toro Super Recycler GTS 6.5 HP. Upon
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Posted on Jul 22, 2010
#1 Taper
  • 1040 Answers
SOURCE: have a toro recycler white
This is not a good sign!! You have blown a head gasket, the rings around the piston have gone bad, or you have blown a hole in the piston.The head gasket isn't so serious, and it may be worth fixing. However, the other two scenarios are serious and wouldn't be worth fixing if the mower is old.
Good Luck!
Jim
Posted on Aug 05, 2011
#1 Taper
  • 1040 Answers
SOURCE: Was using my toro lawn
You have big problems my friend! You have blown a head gasket, or broke the rings around the piston. The gasket isn't as bad as the rings. But neither is a good sign. It may be time to get a new mower; sorry for the bad news..... :-(
Jim
Posted on Aug 12, 2011
nelsondonnel
SOURCE: I have a Toro Time
What you have is an engine that has a carburetor problem that has probably diluted the oil to the point that the crankcase is over-filled. Drain the oil and filter, then replace oil. Sometime the carburetors on these unit will become porous or cracked inside and will allow gas to enter the fuel bowl while the engine is not running. Some signs of this is that the engine will drag or static lock when you try to crank it over.
I've gone to the point to even put an inline fuel shut-off valve in the fuel line so that the fuel can be shut off when the engine is not running to temporarily deal with this problem until a new carburetor can be located and installed.
Posted on Sep 13, 2012
Excessive white smoke from tail pipe
White smoke:
White smoke is caused by raw, un-burnt fuel passing into the exhaust stream. Common causes include:
·Incorrect fuel injection timing
·Defective fuel injectors
·Low cylinder compression
Low cylinder compression may be caused by leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze. When white smoke occurs at cold start and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing.
Continuous evidence of white smoke indicates a mechanical defect, or incorrect fuel timing.
Jan 25, 2015 | Chrysler PT Cruiser Cars & Trucks
Blueish white smoke comeing from exhaust
Hello There
White smoke when first started is normal. If white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket.
Black smoke is caused by a rich fuel condition.
Blue smoke is caused by oil consumption.
You need to check your oil cap for yellow/white gunk on the cap if you have this then this is a sign your head gasket is cracked. Check to see if your radiator coolant level is down this is also another sign.
Hope this helps. Please don't forget to rate me.
Many Thanks
May 20, 2009 | 2004 Chrysler PT Cruiser
What is causing my kawsaki 580v to smoke
you check the oil with the dipstick resting on the tube, not screwed in
then check your fuel supply as it might have water in it
then remove valve covers and see if you have a valve guide seal that has moved
May 16, 2014 | Kawasaki Engines NEW 19 HP KAWASAKI ENGINE...
Ford focus tdci white smoke problems
What happening is you have a bad head gasket or its starting to go bad. As long a little oil is getting in to cylinders causing that smoke once it warms up that gasket is expanding thus the smoke stops. I would keep an eye on oil levels if it gets milky replace gasket asap. Could also be intake gasket but highly doubt it this sounds like a worn head gasket.
Nov 27, 2012 | 2006 Ford Focus
Have a toroZ5035 mower 90 turn) with kawasaki engine. **** smoke appears on start up, but goes away when warmed up. choke must be kept on at least halfway or motor dies. changed plugs and cleaned air...
**** smoke sounds bad, If what you meant was white smoke then I know what is going on with the mower. The white smoke is from the extra oil in the cylinder head. There are tow causes for this. #1 the engine rings are worn and will not prevent the oil from running into the combustion chamber as the engine sits. #2 the carburetor is leaking fuel into the oil and thinning it out. This thin oil bypasses the rings easier and drives the oil level up too. I would recommend a carburetor rebuild. You can get parts from a local dealer like www.arcolawn,com Good luck barterjoe_64.png
Mar 23, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
Car has white smoke some says it's rings and some say it's over fueling
Excessively rich mixture will give black smoke. Blue/white smoke is oil. If the smoke is present when you start the engine or run against compression only, the probable cause is the valve stem seals. If the smoke is continuous it will usually be due to rings that are worn. (Check that the sump is not too full).
Feb 08, 2011 | 1997 Volkswagen Jetta
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Mower starting but smoking heavily, just topped off oil in Toro
Mowers smoke for the following reasons:
Too much oil.
Badly clogged air filter can cause oil to be sucked by piston rings.
Worn piston rings.
Worn cylinder walls.
Cracked block/piston.
Excessive blow-by getting sucked into carb. Caused by worn rings.
The only thing most people can fix is the too much oil or clogged air filter. Try those first.
Apr 04, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Toro Zero Turn Rider 74833 Lawn Mower Tractor Rider Ztr Logo
186 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
