Question about Ridgid Drills
Why will my battery charger vpx 0310 will not charge battery?
All of a sudden this battery charger will not charge my lithium battery
  • 8 Answers
SOURCE: Will the ryobi nicad charger also charge the
No, but the Lithium charger will charge the NiCads.
Posted on Apr 01, 2010
HomePlicity
  • 41 Answers
SOURCE: Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Testimonial: "This is the best answer I received! Thanks!"
  • 127 Answers
SOURCE: can you charge ryobi lithium batteries in a
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Posted on Dec 27, 2010
  • 2428 Answers
SOURCE: porter cable 18 v lithium
How old is the battery and do you store it in the cold. Cold is no good for the batterys but if its flashing that its trying to change and the problem may be with the charger if there not more then 3or 4 years old and were not left in cold conditions and the lithium battery haven't been out for much longer then that. Ihave the same gun and for a year its worked vary well with the 7 inch saw and i use them a lot.
Posted on Dec 28, 2010
  • 4 Answers
SOURCE: Makita 18v lithium battery when put on charge
This isn't true because I have a second charger and it works fine
Posted on Nov 19, 2011
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
DEWALT DW938 18VOLT CORDLESS SAWZALL can it use Lithium Batteries
As long as the voltage of the battery is the same as the tool, the tool won't mind if the power is coming from a NiCd or lithium battery. You do have to have a charger that works with lithium batteries to charge them up. Chargers that can charge lithium batteries can also charge NiCd and NMH batteies. NiCd chargers are not always programmed to detect when lithium batteries are full and may continue to charge them to the point of melting or starting on fire.
Jan 31, 2011 | Dewalt Dw938 18v Cordless Reciprocating...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can you charge ryobi lithium batteries in a regular ryobi charger?
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Can you charge a 18v lithium battery in a nicd charger?
Do not try this since the charging circuit for lithium batteries are different than nicad! Improper charging of lithum batteries can cause a fire.
Dec 06, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Will a nicd charger work to charge lithium-ion batteries?
no, I would not try this. You can charge a nicd battery on a lithium-ion charger but not the other way around.
Nov 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Recently bought Craftsman Lithium battery & charger that failed.
Sounds like your charger is only for NiCad batteries. With most brands, the new Lithium chargers will also charge the old NiCads, but the old NiCad chargers will not charge the new Lithium batteries. You will be very happy with the lithiums once you are able to fix the problem. As for Craftsman, buy Craftsman hand tools such as wrenches and sockets but I'd look elsewhere for battery powered tools.
Mar 25, 2010 | Drills
Drills Logo
82 people viewed this question
Top Ridgid Drills Experts
Tim Whalen
Bill Boyd
Are you a Ridgid Drill Expert? Answer questions, earn points and help others
