Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
How to remove plastic freezer drawer in French door fridge
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a Fisher &
The drain may very well be blocked with ice....that is not at all uncommon...
Let the fridge off for a day to clear any ice and then blow through the drain to make sure it is open...
Then follow this tip to install a heater that will keep the drain open...
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 07, 2010
  • 19 Answers
SOURCE: Fisher and Paykel French door, freezer drawer, F24 and flashing wrench symbol. Help
That's a water filter error code.
Did you just change the water filter? If not, do so.
If you didn't change it or changing it doesn't solve it, the next step is to ensure there's no air trapped in the system. Get 2 or 3 glasses of water at the door.
If the error code still shows, press and hold the Filter button for 10 seconds which should re-set the code.
If that sorts it out, let us know what worked please. This helps other people with a similar problem know.
However, iIf you still have trouble and the appliance is still in warranty (possibly 2 years or more depending on where you bought it), call the company and provide the model and serial number and they should be able to tell you.
If in warranty, arrange a service call.
If not, let us know what you did and we'll go from there. Good luck!
Posted on Jun 03, 2015
Testimonial: "I hadn't changed the water filter but after doing so it made no difference. I eventually called a serviceman out and he said it was the sensor wire to the ice maker. The old one was changed to a new silicon encased one. Fridge stopped beeping problem solved...... So I thought. At 7am this morning the fridge cut my power. Calling them back out tomorrow."
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have a Liebherr free standing french door frig (two freezer drawers). The plastic component that shapes the ice cubes has fallen out of the ice maker into the ice receptacle below. I don't know how to...
I don't know about this ice maker, but you could always check the Owner's Manual (either the one that came with fridge, or an online copy) for re-attachment info. That's something basic that the manual may very well cover.
Sep 18, 2013 | Liebherr CS2062 Bottom Freezer French Door...
I bought a kenmore refrigerator model 71303... a french door model with nothing on the doors (dispenser-wise) and a pull out drawer freezer. fits the space in my kitchen perfectly, however I just...
Unfortunately, 71303 is not a complete model number, even though that is how Sears lists the unit here: http://www.searsoutlet.com/22-7-cu-ft-French-Door-Bottom-Freezer-Refrigerator/d/product_details.jsp?pid=41106&mode=seeAll . However, most french door refrigerators can have the doors and freezer drawer removed. I think your model number will be 795.71303* (there are a few digits omitted). The manual is available here: http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1103856L.pdf . The directions for removing the doors and freezer drawer start on page 11 (page 10 of the PDF).
The 795.71313 is a similar refrigerator. The directions to remove and replace the doors and freezer drawer is given starting on page 13 in the manual. See that manual here: http://c.shld.net/assets/docs/spin_prod_946454012.pdf .
I hope this helps.
(Kenmore refrigerators are made by other manufacturers. The three digit prefix in the model number is important to find the correct manual. A different French door refrigerator, 106.7200*, can have the doors removed. However, only the front of the freezer door comes off. That manual is here, http://c.shld.net/assets/own/spin_prod_734629012.pdf; see page 10 and subsequent pages.)
Mar 12, 2017 | Kenmore Refrigerators
Freezer drawer on french door keeps coming off on one side and also internal ice maker not making ice
The drawer should have a plastic clip this will need replacing (I think) I say I think as they some times break the drawer and not the clip. the ice maker takes upto 36 hours for it to work, providing the fridge is plugged into the mains water supply via a small white/grey long tube.
Aug 04, 2010 | LG Refrigerators
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
My Kenmore Elite french doors bottom freezer drawer fridge has condinsation in the top of my fridge what is causing this?
bad/dirty door seals allowing fresh moist air in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 24, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Jan 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
