Question about Ruud Heating & Cooling
What is the SEER rating of outdoor model #UAPM-048-JEZ with indoor coil RCFL-M-4821
22yooper
  • 828 Answers
SOURCE: Size and SEER rating
2 ton (24,000 BTU) 10 SEER
Posted on May 22, 2008
  • 306 Answers
SOURCE: need recommended sub-cooling and superheat for
Superheat should be 8 to 12 degree's. Sub cooling around 18-22. I like to use superheat that way I know the coil is doing all it can do.
Posted on Jun 16, 2009
SOURCE: what is the seer rating and tonnage of a bryant
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
Posted on Feb 17, 2010
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
BillB-SA
  • 2761 Answers
SOURCE: I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND
Yours is a 3 ton unit with a SEER 10 rating.
Posted on Jul 13, 2010
Water leaking from unit
possible low pressure of refrigerant and freeze coil indoor unit, check filter maybe it's dirty
Jul 07, 2015 | YMGI R410A Ductless Mini Split 16 SEER DC...
Rheem error codes
error code 29 is a high pressure open. possible causes are dirty indoor or outdoor coil. indoor or outdoor fan not running, liquid line Freon restriction, or to much Freon in the unit.
Jul 30, 2014 | Rheem RPRL048JEC 4 Ton 16 SEER Heat Pump...
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
What is the seer rating?
To be able to give you that info. we need a make and model number of the unit you are asking about...
Need both the indoor coil model number and the outdoor model number...
heatman101
Sep 17, 2010 | Heating & Cooling
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
Heil Heat pump model # NHP218AKC2, I need the specs to replace an old unit in the other side of my duplex
I can help you on part of your question, the system that you listed above is a 1.5 ton unit, if I had the serial number I could give you the age of the unit. If it is a late 1990 model, then it is probably a 10 SEER unit, maybe a 12 SEER, if it is older than 1994 it will be a 8 to 10 SEER, but due to new federal rules, all new heat pump or air conditioners are at least 13 SEER. If you just replace the outdoor unit and leave the coil indoors, it will be mismatched and cause the unit to be less effeciant, and some problem in adjusting the Freon levels.
Ideal is to change the outdoor unit and indoor coil.
I hope this helps, I am new to this site, so I am still trying to get to the point, and yet give you the details that you need.
Sincerely,
Paul Gibson
Mar 29, 2010 | Goodman Heating & Cooling
Just had the haier 4 ton 13 seer outside unit installed. my inside unit is a payne and still in good condition.had a 4 ton 10 seer outside unit previously. my problem is the unit froze up the first night...
Your problem is that your 13 seer outdoor unit is not compatible with your 10 seer indoor unit, even though the tonnage is the same. The metering device on 13 seer indoor units is different. Most 10 seer indoor units do not have an expansion valve. When you change from a 10 seer outdoor unit to a 13 seer outdoor unit, you must, at the very least, change the from a fixed-orfice metering device to an expansion valve.
Jul 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Have 9 yr old Carrier model 3BTRA-048 12 Seer AC. IT has stopped cooling / Called Co that installed it/ TEch came out and checked outside compressor, it was ok/checked inside coil it was freezing 1/2
I wouldn't be so fast to say that it isn't low on R22. What are the indoor and outdoor temps? If there was a restriction I would expect the high pressure to be higher. I would definitely get a second opinion. Some companies will give free second opinions. Don't tell the second company what the first co. diagnosed until after they diagnose it. Just tell them what the symptoms are.
Apr 25, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
