Question about Epson Office Equipment & Supplies
Epson Stylus CX7400 won't feed/load any type/size of paper
My printer won't printer on any type of paper.. its an Epson Stylus CX7400 and it has worked fine for like two and a half years and all the sudden one ink was out and i changed it then as soon as that one was replaced another color was out so after going through this and replacing all four colors all the sudden it decides to not actually load/feed the paper. it sounds like the wheels are spinning and sounds normal in all ways but the paper doesn't go anywhere. I am a student and need a printer but don't have the money to go by a new one. Is there anything else I can do?
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
You may have gear, roller problems. Try the head alignment process, if need be call Epson tech support. Epsons are really cheap if you need a printer. If you are going to buy a printer then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Posted on Jun 23, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper jam light keeps flashing, but no paper jam can be seen. Won't print .`
Open your printer paper feeder. Then look inside it. There is plastic roll inside it. That is the curlprite. Try to open it. at the last stage you may see a spring that usually is in the plustic rollar's holle. Remove it and re assemble carefully. That's ok.
I think you will be relive from your printer problem.
Thank you.
Jun 15, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I need to restore the software for my Epson Stylus CX7000f PRINTER in my new computer. I can not find the original disk, from where can download the software
The Epson Stylus CX7400 Color All-in-One printer prints up to 28 pages per minute of black ... Stylus CX7400 ink jet all-in-one, 69 black ink cartridge (T069120), ... Best of all, you don't need to wait for an available computer to get started. .... Also, given my experience, one paper jam can cause your printer to ...
www.amazon.com/Epson-Stylus-CX7400-Printer.../B000SDXZX8
Jul 16, 2010 | Epson Stylus CX7400 AllinOne InkJet...
Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Jan 01, 2010 | Epson Stylus Photo R300 InkJet Printer
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
I do not have the disk that came with my Epson Stylus CX7400 and I cannot install it. What do I do??
You can download the software and drivers at the Epsom website for Stylus CX7400.
These links give you all the software you will need - select drivers and utilities combo package for your operating system.
Windows
Mac
Overview, troubleshooting and links for CX700
Documents and Manuals including installation guide
Hope that helps you :)
Nov 18, 2009 | Office Equipment & Supplies
Whats going on with my printer
Replace paper feeder. Or find at aicaxz solutions about fixing paper jam without replacing.
Sep 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
R320 WILL NOT LOAD PAPER , ANY SIZE
Hi
Better get a new, call epson at 562-276-1300 so that you can have a discounted brand new printer from them.
Hope this helps
Nov 28, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R800 (Manual Feed) missing option
I found this answer on Apple.com support discussions.  Worked for me.  There is more information available on the discussion, but this was enough to fix my problem. Try Page Setup. Select to format for your printer. The choices for different all media should now be available under the Paper Size. This is a change from previous practice of creating a separate printer for each type of media.
Matt
Sep 22, 2008 | Epson Stylus Photo R800 InkJet Printer
Printing
seems that y´all experiencing various paper feeding issues
check first for recommended paper type
that printer should handle 4x6´s up to 8.5x11´s
and if it can´t feed a particular size - hardware issue & check your warranty status with the manufacturer
Dec 24, 2007 | Epson Stylus Photo R320 InkJet Printer
708 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
