Question about Garden
Craftsman Lt 2000 riding mower turn key get click click battery good
    New Friend:
  • 32 Answers
If your getting a clicking noise that would be at your solenoid. if you can take a screwdriver and place it across the two post the two large red wires are connected to and it kicks in the starter on the engine you need to replace the solenoid. be sure to hold the handle while doing this and not the metal part of the screwdriver. and don't be startled when it arcs and starter kicks in. how this works is when you turn the key power travels down a small wire from the ignition switch down to the solenoid little post and closes the connection between the two larger post with the red wires to engage the starter. sometimes the connection inside between the two large post isn't made and the solenoid becomes no good. by crossing over between the two large post externally with a screwdriver your doing the same thing as turning the key to start. you can start the mower that way until you get a replacement solenoid. just be sure to have key on when jumping across.if you want it to stay running. Good Luck
Posted on May 17, 2014
2 Suggested Answers
  • 19 Answers
SOURCE: lost key to craftsman lt 1000, where can I get raplacement
sears has them on a hook where the filters are located.
Posted on Jul 19, 2010
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor · Operation Manual.Craftsman Lawn Mower manuals - ‎Craftsman 247.370310 - ‎Craftsman 247.37030
Aug 02, 2015 | Craftsman Garden
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Lt 2000 craftsman riding mower wont start by key only jumping cylanoid
Bad ignition switch or bad solenoid (there is no such thing as a "cylanoid"). Start by testing continuity through the ignition switch and, if the ignition switch is good, replace the solenoid.
Jul 20, 2014 | Craftsman Garden
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
I have a craftsman 18.5 hp twin model 944.607390 that will not start. when you turn the key it just clicks.
check connections at battery and the battery if good check the fuse by solenoid if good need to test the solenoid itself
May 18, 2010 | Craftsman Garden
My LT 2000 lawn tractor starts to turn over but turn once than stops. What is wrong?
Dead battery ... replace it ... at best, you will only get 2 years out of this size battery.
Mar 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a craftsman 17.5 hp bought 7 or 8 years ago. Has "LT 1000" on its engine cover. Went to start it. Turned the key in the ignition, "nothing happened, checked battery, appear,o.k. The battery guage...
Yes, you may hear a small click when the key is placed in the run position. It is the fuel solenoid (on the carburetor) activating.
If it is a large click, then that is the pto clutch activating (as in the blades are ON) and that will not allow the engine to start.
Sometimes when a battery is low or connections at the battery are dirty, you will hear a click, that is the solenoid activating, but the battery voltage is low enough that the starter will not turn. Sometimes this condition has a chatter.
Easiest test for this situation is jump start from you automobile, or charge the battery for an hour, and see what happens from there.
Nov 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT 2000 riding mower
Check the motor of craftsman LT 2000 riding mower
Aug 25, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
