Question about Electrosport 1994-1998 Yamaha Yfb250 Timberwolf 2wd Atv Plug-in Electric Regulator
Wont turn over
Battery has over 12volts but still does not crank over
Battery no problem car wont start clicking sound
your battery is to low in power to start car or your starter or solenoid has packed it in .
Apr 03, 2014 | 2001 Mitsubishi Mirage
Car ran fine until I pulled into driveway. After I turned off ignition it wouldnt start again.
Have the battery tested and clean the battery cables. Just because it reads 12 volts doesn't mean it can supply power under a load.. Autozone and others test batteries for free
Aug 09, 2012 | 1989 Lincoln Town Car
I have a 96 cobra when i turn the key everything comes on but it wont turn over
first of all have the battery tested, but its probably a bad starter. test for power at the starter, if 12volts on both positive wires when in crank mode wiring is ok.have someone knock on the starter with a hammer while the key is held in crank mode, if car starts replace the starter. if not attempt to turn the crankshaft by using a socket and breaker bar, on the bolt that holds the crank pully on. if unable to move crankshaft replace the engine
Oct 11, 2011 | 1996 Ford Mustang
I have been building a chopper out of this model bike, have the bike complete but it isn't starting. It trys to turn over but it wont fire up.
To begin with you need a good battery @ 12Volts.
Check if there is spark at the spark plugs.remove one spark plug and earth it (spark plug body) and crank start and observe for the spark.
Check if fuel ( gas ) gets into the combustion chamber.
Try cranking it and thn remove the spark plugs and check if they are wet with gas.
Basically these are two things to check first.
Hope this helps!,
Let me know of the outcome and hope to be of help further..Thks.
Nov 29, 2009 | 1983 Yamaha XS 400 L Maxim
Wont start wont crank
YOUR PROBLEM is either Battery lower than 12volts or Starter Motor Jamed in or burnt out ,or battery lead loose on battery, or on the engine block (Black wire is earth) bolt could have come loose on engine,,
To try ,turn on lights, turn to start if lights go out then Battery flat or no good ,,if lights stay on when key turned on nopower to starter .
Let me know the out come of it Ron
Oct 05, 2009 | 2007 Buick Century
My car wont even turn i have tryed trobleshooting the safety devices and they are working properly. i have a new battery and a new starter
go directly to the starter and see if you have power ( 12volts) at the main cable and 12volts at the trigger wire with the key turned to the start position. If you have both, likely the starter has failed. If no power at the trigger, you may need to look at large underhood fuses and check ignition and neutral safety switches as well.
Sep 07, 2009 | 1993 Saturn SL2
Starter motor wont turn over
Make sure car is cold. Battery must be fully charge. Make sure all battery connections and to starter and engine/body are clean and tight. Have someone cranks the car as you check for cranking power to the starter solenoid;it is the smaller wire on the solenoid which you may need to remove. Do this test at least ten times using a 12volts test light. If power on every crank, it definitely sound like starter acting up. Keep me informed.
Jun 14, 2009 | 1992 Nissan Sentra 4 Door
1996 cad deville real low on gas, wont fire
I would add 5 gal of gas first. The gas line pickup in the tank might not be delivering gas
Apr 20, 2009 | 1996 Cadillac DeVille
Car wont start.1990chrysler newyorker 3.3 my car will not start.replaced switch,tested starter still nothing.
if it will not crank have you checked all your fuses and relays? there should be a crank fuse and a starter relay. is the relay functioning propperly. next check at your starter yould should have a larger wire that is hot or has voltage on it at all times directly from the battery. there should be another smaller wire that comes from the ignition and at the keys crank position you should get 12volts on this wire this is what energizes your solenoid on the starter. not sure if you have already checked this hope it helps
Feb 10, 2009 | 1990 Chrysler New Yorker
Electrosport 1994-1998 Yamaha Yfb250 Timberwolf 2wd Atv Plug-in Electric Regulator Logo
57 people viewed this question
Top Electrosport Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrosport Electrical Supply Expert? Answer questions, earn points and help others
