Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Have a poulan leaf blower and it wont start but there is spark at the plug and the plug is new
  • 1,057 Answers
Put gas is the carb. and see if it runs for a short time if so then you have a fuel delivery problem. Hope this helps.
Posted on Oct 20, 2016
  • 15 Answers
SOURCE: Poulan Pro 200 Leaf Blower won't start. I have
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
Posted on May 30, 2009
  • 15 Answers
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
#1 Taper
  • 1041 Answers
SOURCE: poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Posted on Jun 09, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
Can't start poulan ppbp 30 cc gas blower
At all? Check the plug to see if it's wet. If so you are getting fuel so problem is spark. Get a new plug and gap properly. What else have you tried?
May 06, 2012 | Poulan Garden
No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
Jan 07, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Nov 02, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
202 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
