Question about Motorola Mobility DROID RAZR Maxx 4G Mobile Phone - Black Verizon Wireless MOTXT912M
Removing battery how do I remove the battery?
  • Official Brand Answer
  • 1,623 Answers
This phone has a non-removable battery.
Mark
Motorola Support
Posted on Jan 06, 2015
How to remove the battery
Always remove the negative battery cable first. That will avoid the possibility of causing a spark trying to remove the positive first.
So you take a wrench and remove the negative post. If it is a sidepost battery, use an 8 mm wrench to remove the center bolt on the cable. If a top post battery, use the appropriate wrench to remove the negative cable terminal.
Now you can safely loosen and remove the positive battery connection.
Battery is now free to remove, but wait, there is a holding fixture on most batteries so it won't move around or tip over. Either a top bracket that hold battery stable, or there is a small little block at bottom of battery, like a wedge, to hold it secure. This block or wedge is retained by a small bolt, usually 1/2 inch size hex on the bolt (or 13 mm size, which is very close to 1/2 inch). remove this holding block or wedge and battery should come4 out. On some GM models there is a brace which is over the battery, and this brace must be removed for battery removal. Take one end of brace loose and swing it out of the way.
Apr 04, 2017 | Cars & Trucks
How to replace an alternator on 1999 intrigue oldsmobile
For a 3.5L
Remove Cross braces above battery and air box
remove battery
remove battery tray
disassemble air box
remove engine computer
remove air box
remove radiator fans
drain coolant
remove coolant resevoir
remove serpentine belt
remove thermostat
remove alternator out hole that battery was covering.
Install new thermostat seal.
Aug 27, 2014 | 1999 Oldsmobile Intrigue
Remove battery
  1. If equipped with power seats, move the seat to the most forward and upright position.
  2. If equipped with manual seats, move the seat to the most forward position.
  3. Turn the ignition switch to the Off position. Be certain that all electrical accessories are turned off.
  4. Remove the battery cover (1).
  5. Remove the negative battery cable (1) from the battery.
  6. Disconnect the positive battery cable and position aside.
  7. Remove battery thermal blanket.
    1. Remove the battery hold down retainers (2) and remove the battery hold down (1).
    WARNING: Wear a suitable pair of rubber gloves when removing a battery by hand. Safety glasses should also be worn. If the battery is cracked or leaking, the electrolyte can burn the skin and eyes.
    1. Remove the battery from the vehicle.
Jul 12, 2013 | 2012 Jeep Grand Cherokee
Remove battery from 2002 dyna
The Dyna battery can be removed by:
1. Remove the seat.
2. Remove negative connection at frame, and positive connection at battery.
3. Remove the lower rear bolt. (left side of battery box at frame upright)
4. Remove the upper rear bolt, and swing down the battery box.
5. Remove the top cover, nad side cover.
6. Lift battery out, and remove negative cable from battery.
Feb 05, 2011 | 2002 Harley Davidson FXDL Dyna Low Rider
How to get to battery to change it
1. Remove the seat.
4. Remove hte upper rear bolt, and swing down the battery box.
Jan 20, 2011 | Harley Davidson FLHTCUI Electra Glide...
How do i remove a battery from a 2002 chrysler concorde
Battery is behind the front left wheel. You have to remove the wheel to replace the battery. (you can access the battery w/out removing the wheel, but you can't actually get the battery out unless you take the wheel off.)
Once the wheel is off, remove the inner-fender well mud-guard and you will see the battery just forward of the wheel well. From there it's pretty straight forward.
Once this is removed, you should be able to see the battery hold-down bolts.
Remove these and remove the hold-down assembly.
If you are removing the battery, remove the 1st battery cable.
Depending upon what battery you have, you may be able to slide the battery back toward the wheel and disconnect the 2nd cable.
Jack the vehicle up, put on jack stands and remove the passenger side wheel.
On the front side of the wheel well there is an access panel that needs to be removed in order to access the battery. There are 6-8 1/4" screws to remove. Then manipulate the cover until you can remove it, bending it slightly.
If you were unable to disconnect the 2nd battery cable earlier, you can now move the battery further towards the rear of the car. Remove the 2nd cable clamp from under the hood.
Slide the battery all the way out. It is heavy!
Reverse the instructions for reassembly.
Aug 17, 2010 | 2002 Chrysler Concorde
I need to replace the battery. How do I do this?
Hi!!
The battery is located in the fender, ahead of the right front tire. Te battery can be removed without reovint the tire, but removing it improves access.
Here is how to remove/replace the battery
Disconnect battery cables, negative first, then positive from remote terminals.
Remove air filter housing
Remove the two battery hold down clamp bolts and clamp.
Loosen right front tire lug nuts, rise the vehicle, support it w/jackstand and remove wheel.
Remove battery cover/splash shield from wheel well
Slide battery toward rear of vehicle and disconnect battery cables.
Remove old battery thru wheel opening and insert new one.
If helpful, click below
Apr 13, 2010 | 2003 Chrysler Concorde
Dead battery
Removal Procedure
Disconnect the negative battery cable
Remove the wheelhouse liner.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Install the battery hold down retainer and bolt.
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts.
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Install the positive battery cable (1).
Tighten the positive battery cable bolt.
Close the positive battery cable connection cover.
Install the wheelhouse liner.
Connect the negative battery cable
Oct 15, 2009 | 2006 Pontiac Solstice
Battery removal
The battery is located under the right front fender behind the tire. Remove the wheel, remove access panel from fender well. From engine compartment, remove 2 battery hold down bolts,10mm, slide battery rearward to remove battery cables.
Oct 18, 2008 | 2003 Chrysler Concorde
Motorola Mobility DROID RAZR Maxx 4G Mobile Phone - Black Verizon Wireless MOTXT912M Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
