Question about Birds
Wingspan how long its wings
Why do wings tend to bend upward on a plane?
The entire weight of the aircraft is being supported by the wings. Longer wings are designed to bend upwards to support that weight. Due to the curvature of the wings (more curved on top and flatter on bottom) there is low pressure on the top of the wings and higher pressure under the wings. So the wings are actually pulled up into the air by the low pressure over the top of them.
Jan 04, 2017 | Aircrafts
Is there any advantage to passenger jets carrying fuel in sealed tanks in their wings?
As the wings are lifted by differences in air pressure and gravity acts on the fuselage, the extra fuel load in the wings won't really affect the curvature. Rather, this is for the large storage capacity (volume) of the wings, and the safer option that your fuel tanks are outboard, rather than crew / passengers sitting directly on top of a "belly" tank. In event of a fuel-fire or crash, there is still a chance of fire being extinguished, or fuel-laden wings breaking away in a major crash. The spread-out mass of the wings also adds to stability by increasing the inertia.
How do I do a Pin Stitch with a wing needle on my Janome 12000?
I believe you pretty much use a wing needle like you would a regular needle. These links may be helpful:
What is winged needle
How To Sew Hemstitch Using Wing Needle
Tips on Using Wing Needle
Be sure to practice on scrap fabric before using it on your garment.
Oct 05, 2016 | Janome Sewing Machines
How long is a peregrine falcon wingspan
http://animals.nationalgeographic.com/animals/birds/peregrine-falcon/
Jun 18, 2014 | Radio Communications
When it comes to bird cages, why is size so important?
Cage size is a very crucial element in regards to proper bird care. The tail of your bird should never touch the back or bottom of the cage when sitting on their perch. A very general rule to follow is that the width of the cage should be at least 1-1/2 times as wide as your bird's wingspan. Keep in mind that it is not just your bird(s) inhabiting the cage but you will need a perch and most likely some toys. My personal recommendation is to buy the largest cage you can afford.
Aug 29, 2012 | Birds
Cutting cost on wing production, resulting in a nasty crash!
i normaly only repair large aircraft, but it seems your old good wing was fatigued from regular use and broke, and the new ones are of poor asian quality, thats why they are snaping. i assume the wings are folding up, so on the bottom attach a very thin wire (stainless lockwire if you can get) to the ends of the wing to fuse, at least 30 deg. from wing (like bottom of wing to bottom of fuse)
Jul 24, 2009 | Hobby Zone Aerobird 3
Where can i find a manual for a t-mobile t wing
I was searching for some questions on the wing and came accross this site.
http://safemanuals.com/user-guide-instructions-owner-manual/HTC/WINGS-_E
If you look arond on this web page there is a free download of the Wing Manual. I didn't do the download myself just so you know. Maybe it's was you are looking for. LY
Dec 25, 2008 | T-Mobile Wing™ Smartphone
Building instructions for the ultimate 120 bipe
have a look on rcuniverse website for your aeroplane, there is probably a build thread on there, a 110 fourdtroke will be fine, use the best servos you can afford, i like to use hitec 645 servos, 9kg pull, suitable up to 70inch wingspan models
Dec 21, 2008 | Ultimate Sound Ultimate 120 - 55" Nitro...
Birds Logo
88 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
