We had to change the film and now we can not receive faxes unless we push the manaul button
  • shadycreek Jun 23, 2009
    No it is on auto but the phone only rings unless we hit the manual button and then it will come through. The make and model number is Sharp UX-510 and we are getting very frustrated because we are waiting for numerous faxes.
    Thank you so much
  • 10,515 Answers
You might have disabled the Auto-Answering mode. Check user guide and enable Auto-Answering mode.
If problem still arise, get back to me with make and model of the Fax Machine.
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
  • taran_2005
    taran_2005 Jun 23, 2009
    Try to change the mode to Auto-Pick up or reset the phone.
    The link for user manual is :-
    http://www.sharpusa.com/files/fax_man_ux...
    I doubt the settings that might have been played. If all the settings are correct as per the manual, Reset the phone.
    If problem remains, there is a HARDWARE ISSUE. Call tech.
    Hope i have helped you.
How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
************************************************** i will also put in the link for the manual for additional assistance: http://www.lexmark.com/publications/pdfs/4200/eng/frameset.html
Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Canon JX210P Operation manual
cant send a fax but keeps saying check printer 5100?
Oct 22, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
New film in Brother 885-now paper and fil jam
2 reasons.
1.You have not installed the film in correct manner
2.Your film is not geuine brother film.
Jul 30, 2010 | Brother IntelliFAX 885MC Plain Paper...
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Canon PIXMA MX310 All-In-One - faxes storing instead of printing
When the machine is in one of the following situations, the fax is automatically stored in memory.
- If ink is low or has run out while receiving a fax
- If the paper size/type setting is incorrect
- If the paper has run out while receiving a fax
- If the Output Tray is closed
- If OFF is selected for AUTO PRINT RX
- If you pressed the Stop/Reset button to cancel printing of a fax
The most likely problem is that the ink is low.
You can change the settings to still print if the ink is low by pushing the fax button and then the menu button.
Scroll over until you get to RX settings (I think it is the 6th option) and push OK.
Choose the option to Auto Print RX, and press OK.
Make sure that On is selected and even if it already is the chosen option, press OK.
When the option appears to print with no ink, select yes. This will allow the fax to print even when the ink is low.
Sep 04, 2008 | Canon PIXMA MX310 All-In-One Printer
Hello, I have a little used 18 mth old Sharp FO P610 fax machine. It receives fine but when sending the recipient receives 'black all over' pages. I have tried disconnecting the unit for an hour and...
Try just making a copy and see if you have the black lines on your copy (most fax machines have a basic copy function if it is you have dirty scan glass and on these small machines it is a real hassle to get too and clean Try Canned Air. If no black line on your copy it may be the recipients machine.
Aug 12, 2008 | Sharp Office Equipment & Supplies
We can send fax but can't receive...new fax line, old fax machine...panasonic kx-fc195
hi zebaron,
check your ink film maybe its empty, check the receiving mode if its on automatic mode, if its on manual mode you have to press the start button to start receiving fax.
hope this help....
Jul 24, 2008 | Panasonic Office Equipment & Supplies
Fax does not work, and I don't have the booklet for troubleshooting
Cannot receive a fax unless someone is there to push the button to reveive. How can I set up to receive automatically?
Jun 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax number
Press fuction 7 1 key in date & time press set
May 22, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
k24674
jasbo
jasbo
Marvin
Marvin
