Question about Roper RAS8445KQ Top Load Washer
Begins to start then stops - Roper RAS8445KQ Top Load Washer
LG washer makes start/stop sounds at beginning of cycle. Is this normal?
If it works and washes the cloths most likely it is normal.
Oct 07, 2016 | LG Washing Machines
Dryer starts then stops continuously throughout cycle
That's usually a sign that the motor is beginning to go bad.
Mar 21, 2014 | Maytag Dryers
My youtube keeps cutting off and starting form the beginning on my samsung S3!
If a video doesn't play continuously (it stops and starts while you're watching), or stops early, try these troubleshooting steps:
Check your internet connection. You'll need a broadband connection with at least 500 Kbps for the best viewing experience.
Change the video quality to a lower setting to see if the video begins to load.
Pause the video, then change the quality. Allow the gray bar at the bottom of the player to load. Try playing the video again.
If the video still doesn't load, clear your browser's cache and cookies and try viewing the video again.
Nov 19, 2013 | YouTube Videos
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
When we pause our DVD player, the DVD goes back to the beginning of the movie. Is there a way to keep it at the place we paused?
hit stop and if a screen tell you if you want to start where you left off turn off now or if you want to
start at the beginning then press stop again or words to that effect) Do so
Feb 22, 2011 | Televison & Video
GE adora WHDRE526EWW when started it begins to fill then stops filling and have to restart sometimes three to four times help!!!.
I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing, sometimes while washing and sometimes while spinning. I just have to guess when it's going to stop and check on each load frequently to restart it when it stops. Sometimes I can't even get it to start spinning again and I will have to unplug it and plug it back in and then it will spin. Hope someone can help!
Jan 05, 2010 | General Electric WHDRE526EWW Top Load...
How do you start a movie from the beginning after you have started watching it, and then stopped it? Even if I remove the disc and reinsert it, it starts where I stopped rather than at the beginning!
Before the movie loads select the DVD icon and press triangle. Scroll down to Start from beginning.
Also, you can go to the disk menu with Square (or menu/title if you have the remote) and go to scene selection and pick the first scene.
Or, you can fast forward through to the very end and the movie will reset.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
