Question about Behringer Audio Players & Recorders
Wire connections forjt-11p-1 to xlr - Behringer Audio Players & Recorders
    Problem Solver:
  • 17 Answers
Download the pdf file from the address below & you will find it -
http://www.jensentransformers.com/as/as089.pdf
Posted on Aug 20, 2009
Akg c4000b hum
usually humming is caused by defective cables. Check if the cable is wired correctly. Open both XLR plugs and check:
Pin 1 shield
Pin 2 hot (usually red wire)
Pin 3 cold (black, blue or whatever)
Pinnumbers are written near pins usually.
If that doesn't help shake the cable for contact issues.
The microphone could have a broken shield connections as well. Maybe there's a small screw near the XLR output connector. Unscrew (sometimes this screw needs to be turned CLOCKWISE) and check connections.
Apr 15, 2014 | Audio Players & Recorders
Connecting r21s to laptop
The input to the laptop usually requires a stereo or TRS type 1/8 inch plug If the mic has an XLR type connector, you need a special cable that connects the XLR pins 1 and 3 (adjacent pins) to the shield of the 1/8 inch plug and pin 2 of the XLR connector to BOTH the tip and ring of the little stereo jack. Such a cable is not commonly available so the best is to make one from parts you get at Radio Shack.
Mar 12, 2013 | Samson R21S Microphone
My spd s has a bussing soud...I have change the cable and still the same problem
I was using a 25 foot 1/4" to XLR cable from the back of the Roland directly into the Thump. As mentioned, I tried going from the Roland to a direct box with a 1/4 cable on both ends; then out from the direct box "thru"-1/4 fitting, to the XLR connection in the Mackie Thump, with a cable that had the 1/4 on one end and the XLR on the other. Still buzzing. So for grins, I hooked an XLR to XLR cable from the Direct Box Low-Z out, to the Mackie Thump, keeping the 1/4 plug going from the Roland to the Direct box and eliminating the "thru" connection from the direct box to the Thunp, (1/4 to xlr). NO BUZZ.
There is a definite loss of signal strength, ie: everything is coming through quieter, but I can raise the volume of the Thump to FULL, with no buzz, and I can raise the volume of the Roland Module to full, and still no buzz. But there is a definite loss of overall volume, I think because I am not using the direct box properly. Hmmmm. As I understand the Direct box, the IN and THRU are supposed to be used as I was, going from the Roland module to the IN, then from the THRU to the speaker. The Low-Z outs are supposed to carry a signal to a mixer, I suppose to use a FOH PA system, or for recording purposes. Still, I have no buzz. Now...........
In looking over the cords, I suddenly realized that the 25' 1/4" to XLR could be the problem. The 1/4" plug is STEREO! Not mono. Could this be the cause of my buzz? I'm thinking I have a stereo plug, so 2 wires are involved, yet I'm using it in a mono imput in the roland. Perhaps this is creating my ground loop?
After getting a 1/4" MONO to XLR adaptor, attach it to my XLR to XLR cord, go from the back of the Roland (1/4") to the speaker directly (XLR) and see if my buzz is still gone.
The problem now becomes going from the Direct box to the speaker, since it needs to be 1/4 mono from the box, and xlr male to the speaker. I cannot locate a cable like that! So, I guess the next best solution is to get an adaptor to convert one end of the xlr/xlr cable to a 1/4 mono plug. At that point I don't think the cable would still be considered a 'balanced' line though, since it goes from 3 wire at the xlr to 2 wire at the 1/4 ts plug, right? The only other solution is to continue running out of the direct box as I am, using the Low-z out xlr connection, so I can continue to use the xlr/xlr cable.
Also there was a button on the direct box, called a PAD, for -15dB, I assume that what was causing my signal attenuation. When I pushed it in and it released, I suddenly had my volume back.
May 08, 2012 | Roland Spd-S Sampling Percussion Pad...
What are the true xlr connection numbers for bottom blue and red wires
Blue wire connects to XLR pin 2.
Red wire connects to XLR pin 3.
You can find a wiring diagram on Shure's website.
Apr 19, 2011 | Shure SM58 Professional Microphone
Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
Wiring an interconnect
Radio Shack sells an XLR to 1/4" jack converter. The you'll need a female double RCA to 1/4" plug in series with it
Apr 19, 2010 | Behringer EUROPOWER EP2500 Amplifier
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Microphone wiring for DV camera
on both xlr connection, you can see numbers on the plug from the out side and the inside. number 1,2 and three. 1 is for the ground, 2 for the hot wire and 3 is for the return, just match numbers. if you switch them, it will not work. just make sure one to one and so forth. good luck
Feb 20, 2007 | Sennheiser Me66/k6 Professional Microphone
74 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
