Question about GE Refrigerators
Water dispensor problem (zIss420dmass)
Hello All,
I have been having a problem with the water dispensor on my GE side by Side refrigerator. The problem is that the water doesn't come from the dispensor. I have already changed the water valve. even after changing the valve, the water didnt' come from the water dispensor. When I 'd press on the water dispensor, I'd hear a clicking sound, which is the sound of the water valve opening. Strangely 3 hours after I put the new water valve, the water suddenly started coming so I thought the problem is solved. When I woke up in the morning, same problem again. Which is, no water from the dispensor. The ice maker is making ice perfectly fine. My water filter in the refrigerator is bypassed so it is definitely NOT in the picture as well.
I am not sure what to do here. Somebody please help...
Thanks
  • aash73 Jun 24, 2009
    Thansk for your comment. How do I check for either of those?
    Cheers
  • 351 Answers
Hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Posted on Jun 23, 2009
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a water softner in my house do I need the smart water filter on the refrigerator GE model PSS26NGSA GE PROFILE. I use the filter bypass plug but there is no water running thru the dispensor. Do I...
If your using the correct bypass plug which came with the refrigerator , the water dispensor should still work . Make sure the plug is very snuggly , tight in place .
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The indoor water dispenser valve leaks
Clean/rebuild or replace the valve that controls the water to the indoor dispensor.
Dec 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Dispensor drips
You probably need a new water valve in the back of the fridge the valve is not shutting off completely  replacing valve will correct this problem
Nov 13, 2008 | GE GSS25JEMWW Side by Side
Refrigerator wate leak
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Apr 21, 2008 | GE Profile CustomStyle PSI23NGR Side by...
Refrigerators Logo
210 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
