Question about Sony Office Equipment & Supplies
Xl5100 replacement lamp - Sony Office Equipment & Supplies
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Posted on Aug 26, 2016
I bought a new Sony xl5100 lamp. Delicately and accurately replaced the old lamp with the new one. Installed the lamp and housing correctly. Closed the lamp access doors correctly. Turned on TV...red light...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
Jerry
Lampdeng Limited
Jan 11, 2014 | Sony (XL-2400) Projector Lamp for...
Said replace lamp, now doesn't turn on
if it was working before lamp replaced "replace lamp" appeared on the screen either lamp somehow not in correctly, new lamp bad, or something happened during lamp installation--have you tried to put the old lamp back?
Apr 08, 2012 | Televison & Video
I have a Sony KDS-R50XBR1 I cannot remove the "old" XL5100 to replace it I follow the instructions to lift the ring, put my thumb on the groove and pull out Only it won't I cannot see...
XL5100 has lock lever that holds it intact inside tv, you need to put thumb on groove and press it to release the lock then pull out lamp, below image of lamp shows lock lever that moves upward when you press groove so lock gets release and lamp slides out very easily with little pull.
Please check new/ replacement lamp (if it is Sony original, it would be complete lamp including casing) for below mentioned lock function to have better idea how it works.
Hope these info will help you.
Thanks.
Jan 22, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Lamp Replace Counter
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
Sony wegas kdsr50xbr1 wont turn on blinking 4 times whats wrong
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL5100 you can find it here: http://www.discount-merchant.com/Sony-Grand-Wega-XL-5100U-Lamp-p/sony_xl-5100u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 12, 2010 | Sony KDS-R50XBR1 50" HDTV
Red light on front flashes 4 times and picture comes on for 1 second then goes dark and red light flashes
THE FOUR BLINKING RED LIGHTS INDICATE A FAN PROBLEM. CHECK IN THE BACK AND MAKE SURE THE FANS ARE SPINNING ON POWER UP.THE PROBABLE CAUSE IS THE LARGE LAMP FAN LOCATED ON THE LOWER LEFT WHEN LOOKING AT THE BACK OF THE TV
Dec 15, 2009 | Sony KDS-R50XBR1 50" HDTV
Hi..even though just replaced the lamp XL5100 the blacks still look too blue...is there something else thats causing this??
So you have a Sony TV maybe hopefully not but sony has had alot of problems with the light Engines
high failure rate on them! Just wanted to warn you ahead of time .
Dec 08, 2009 | Televison & Video
Sony KDS-R50XBR1 tv.When press on butten,green LED comes on.TV is on for half second and goes off. The lamp led light blinks red four times and cotinue blinking red.
Hi,it sounds like your lamp needs to be replaced this will be the part you need XL5100 found Original Philips lamp here: http://www.discount-merchant.com/SearchResults.asp?Search=XL5100+ God bless you!
Oct 01, 2009 | Televison & Video
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Sep 24, 2009 | Electrical Supplies
51 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
