Question about Garden
I have simplicity sunstar hydro 20 rear pto shaft that wont engage
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 47 Answers
SOURCE: Electric PTO won't re-engage after running OK for a while
might be rust between the plates or you need to adjust the springs tenson there are 3 bolts on it
Posted on Sep 11, 2009
Testimonial: "Adjusting the gap worked. Old gap was .037". I adjusted it to .012"."
  • 38 Answers
SOURCE: My simplicity Coronet Hydro 13 lawn tractor loses
The fluid in the transmission is a multigrade oil. sometimes you can change the oil by removing the transmission partially or entirely and change the oil to a heavier grade like 15W40 or 20W50, the transmission has a vent mechanism on top that is where the oil would be extracted or drained from and then refilled, the level at full cold is 1" to 1 1/4" below the bottom edge of the inside of the vent pipe or plug boss. some of these had a flat vent plug, some have a hose with the vent in the end attached at a nipple and still some older units had a reservoir like on the larger tractors. The reason your trans is slowing is due to wear in the hydraulic pump face.
Posted on Jun 04, 2010
  • 69 Answers
SOURCE: JD 6400 PTO shaft will engage and turn. But it has
Have you went into the gear box. According to your complaint, it sounds like you sheared a key on one of the gears inside the gear box which is making the gear turn but not the shaft.
Posted on Dec 01, 2010
dcurryn601
  • 60 Answers
SOURCE: My LT1045 blows the 20
you have to start with the switch and see if its faulty
see if you can replace it temp with a toggle switch
and check the wiring back to the pto as well it mite be grounding out
If not any of these then its in the pto its self
Posted on Jul 23, 2011
Massey ferguson 135 pto keeps throwing out of gear drives but pto wont stay in gear why
possible that the teeth of the pto dog are worn to a taper and not fully engaged
the lever for the engagement is moving the full travel to engage
the bearings on the pto shaft are failing and allowing misalignment of the shaft thereby walking the dog out of engagement
Jan 05, 2017 | Toys
Rear pto will not engage
Make and model please
Feb 20, 2016 | Garden
Simplicity. How do I test the interlock module?
snapper mower:interlock module - how test?
www.homeownershub.com > Home Repair
May 28, 2005 - 1 post - ‎1 author Snapper 1438H Hydro, rear-engine riding mower. Thing yesterday just quit. ... Next item up the line is the INTERLOCK MODULE... All the safety ..
Sep 05, 2015 | Garden
My PTO wont engage and the mower wont move either. Happened while mowing lawn.
hydro transmission, hydro PTO? check hydro fluid
Aug 25, 2013 | Garden
Sep 10, 2009 | Garden
Simplicity regent mower electric pto suddenly stops working but will work again later.
I have the same problem with my regent. Sometimes i just ride around a few minutes and it suddenly engages. I have no idea why.
Aug 19, 2009 | Briggs & Stratton Garden
Simplicity sunstar 20hp rear pto won't engage deck when you flip the switch, it used to work for a while and I could play with it and it would work but now nothing, any suggestions.
your electric clutch may need adjustment. Take the hood off. Look behind the double pulley that's on the crank shaft. Behind the pulley is an electric clutch. You will need a .010-.015 feeler gage and check between the clutch plates. You will tighten the three screws that mount the clutch to the motor. Try and get as close to .010" as you can. After adjustment start the motor and try and engage the pto. I bet it will work.
Good luck
Jul 18, 2009 | Garden
The blades stop and the 20 amp blowes on My YTH
Hello:
This Sounds like a Bad PTO.
The Following is a Basic File I Made for Checking the PTO (Blade Engagement). The Most Common Cause for this Problem is the PTO Ground. A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO. Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire. Clean the PTO Ground and All the Connections for the PTO Wiring Harness. If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
