Question about Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW
I have an averatec all in one computer and when I turn it on it is very slow to connect and sometimes I get as far as entering my password then the screen will go black and not go any farther. Sometimes if you turn it off and on a couple times it will boot up but not always. Also when it gets idle the screen will go black also and the only thing you can do is shut off the power switch
  • efs_perpends
    efs_perpends May 11, 2010
    What OS are you using?
    Sergeant:
  • 199 Answers
It sound like you need to re image your computer you got something serious going on
Posted on Jun 23, 2009
Does this mean there is no password of bios for the averatec computers???
Does what mean there is no password for the bios. If you can access the bios, there is no password. If you are asked for a password, there is a password. Type it in.
Dec 10, 2013 | Averatec Computers & Internet
Hello, I have an Averatec 3200 and it lets me use the Starbucks network when I get a coffee, but when I try it on the shared internet I have with my neighbor, all it says is "Connected...Validating...
if you were to go to manage wireless networks, remove the network you are trying to connect to. then go to available networks and try to connect again. it should ask you for the wireless password now
Aug 23, 2013 | Averatec 3200 Notebook
Ok here is my problem my son uses the pc for school well i had been gone so it started to run slow finally it brought it to me and i can turn it on and i can see the averatec logo then the panel turns...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
try uninstalling a few unnecessary programs
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then defragment your hard drive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
Jan 13, 2011 | Averatec Computers & Internet
Keyboard popped out and I can't figure out how to
It is a ribbon connector, that hasn't broken or ripped?
There will be a small white recepticle with two levers sticking out each side. They are very small, but they will be the only thing that moves, so you can find them with a bit of poking around)
Pull the two levers forward to where the ribbon will be comming into the recepticle. (see how it aligns together when the keyboard is in it's proper position.)
Slide the end of the ribbon into the recepticle as far as it will go, and with it in place, push the two levers on each side back into their locked position, which will be back in the same direction the ribbon moved to enter the recepticle.
Give the ribbon a tug to see that it's firmly held in position; then before snapping it back into place, try it out by turning on the laptop and testing Caps Lock, or Num Lock keys to see if the indicator lights change.
If the keyboard dosn't work , be shure the ribbon is not dammaged, and that it is seated in the recepticle as far as it can go.
A little practice and you'll be a master.
Good luck with this.
Jan 27, 2010 | Averatec (K981609M1) Keyboard
I have a averatec 5110H notebook, when i power-up i am asked for a password(a large blue box) when i enter my password i then get (setup warning - invalid password----continue------system disabled 00000 ...
It is bios password.
Now if you forgot it then you have reset your bios settings.
For that you have to open back cover of laptop.
Then find motherbord pull CMOS cell from motherbord for 10 minutes then put again to it's position.
Then it not ask for password.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | Averatec 5110H Notebook
Averatec buddy cant find wireless connections!?
As far as i know the it's a keyboard toggle, hold down Fn and hit the F11 key.
Remember to update the driver once connected.
Regards.
Sep 03, 2009 | Averatec 1000 Notebook
Th these PC Desktop problems? Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW Averatec D1002UHCE-1... I have an all in Solve I have an all in one...
Try to work through the steps in this article. or this article.
If that doesn't help, here's a workaround that seems to help in some cases:
"Yea I have the blank screen too for my averatec 3200, but there's an easy work around
for some reason it default goes to the monitor port instead of the screen
all you do is press function screen( Fn F5) twice and you can see again. Whenever you see the blank screen pop up just change."
You might also google 'blank screen at logon' and check for other options, such as here.
If you get windows up, try this:
Run chkdsk c: /f or /r according to these instrucitons & these. (you can also run this from the recovery console or cd).
This could be the result of a driver conflict or issue. Run windows update and check for graphics updates, or follow these instructions to update your graphics/video drivers.
There's also the possibility that the problem is malware related, in which case try to follow these instructions.
Jun 23, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
I tried to download windows xp home edition....
Have you checked your BIOS for a memory check? A bad address in the RAM can cause these kinds of problems.
Mar 02, 2009 | Averatec Tablets & eReaders
My battery will not charge for my averatec laptop. The internal port seems loose and the external charger takes some wiggling to try to stay connected. Is the internal battery connection conneted to the...
I've never worked on this brand, but almost all laptops have the power jack soldered right to the system board. Flexing the power connector can break the solder connections and cause the problems you describe. If there hasn't been any damage to the system board, these connections can be resoldered. Getting to them can be a challenge as it means removing the system board to get at the solder side. But if you have soldering experience, patience, a small screwdriver, and some attention to detail, you can fix this.
The only trouble that may pop up is that sometimes electrical arcing occurs where the connections break, and may burn the circuit board. Sometimes the area can be cleaned and successfully repaired, sometimes it's too far gone. But it never hurts to try the repair. Good luck!
Jan 28, 2009 | Averatec (82-878011-01) Motherboard
Sony vaio pcg-k25 won't stay on after pressing the power button. it powers up to the window to enter my password then turns off on it on. sometimes won't even reach that far, just the led lights go on than...
Please perform the following troubleshooting:
(i) Remove and reseat the RAM modules.
(ii) Remove the Battery and reinsert it after cleaning the metal contact.
If the issue persists even when the AC Adaptor is connected then try to get into the BIOS and check if the Computer restarts or shutdown automatically. Restart the Computer and press the F2 key as the VAIO logo appears to enter into the BIOS window. if the Computer shutdown even when in the BIOS then service will be required otherwise try reinstalling the Operating System.
Jan 22, 2009 | Computers & Internet
Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW Logo
126 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
