Question about Poulan 16Inch 30 HP Electric Chain Saw 1630
What oil do we put into the poulan 3.0 peak hp
  • 45 Answers
I assume you are referring to the Bar/Chain oil?
That would be Almost any Available brand chainsaw Bar and Chain oil, If that is not available you can use New uncontaminated SAE 30 motor oil.
Posted on Jan 08, 2015
What kind of oil should be used with this chainsaw?
Pick up some bar and chain oil. Usually comes in a little container, but I have found it in one quart bottles also. Poulan puts there name on a bottle of the stuff and the bottle is that funny poulan green color. I guess that makes it easier to spot.
Aug 11, 2011 | Remington 16-Inch Bar, 2.5-AMP Motor,...
What kind of oil does a Remington 3.25 (Peak hp) 16"/40, 6 cm Electric chain saw take
You need to use bar & chain oil. It's thicker and stickier that regular oil so it will stay on the bar and chain and not run out of the saw when you are done using it.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
use - husqvarna , sthil brands high quality 2 stroke oil
as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
if you want 2 litres mix put in 40 mils of oil into petrol container
then put in 2 litres of petrol only and give good shake and fill the blower
cheers
Sep 01, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How to change oil in poulan pro 650 series model hp-22 mower
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Apr 14, 2010 | Poulan Pro 22" Self Propelled High Wheel...
How much oil to put in a 12.5 hp motor
start with a 1/4 quart of oil and keep adding until it reaches the full mark on the dipstick.. but don't over fill it..good luck
Mar 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What oil do i use for Craftsman Chain Saw 16'' 3.5 peak electric
any brand bar&chain oil will work the lighter weight oil is best for your electric saw.like 20 weight.
Nov 04, 2009 | Exercise & Fitness
Oil leaks out of it even when not using el-14 electric saaw
Sounds pretty normal to me. Every chainsaw I've ever had leaked chain oil. Unless it's a LOT of oil, it's probably normal.
Aug 30, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan 16Inch 30 HP Electric Chain Saw 1630 Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
