it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.? this is for the Panasonic sa-ht 880.
There are no error codes in the users manual. In this series of models panasonic has standardized error code meanings. F61 means a failure in the power out circuits. Your first option is to remove all your speakers and the associated wiring with the power off. Repower unit and see if error is still there. If not, you have a speaker or wiring problem. If still there, you have an internal failure requiring service.
An F61 error code on your Frigidaire washer indicates a failure of the
drain pump relay. Depending upon the model, your washer may be under
warranty for up to 6-15 years above , so check your warranty's status before
attempting any repairs yourself.
To solve the error code problem apply the below step one after the othe
A power outage can cause error codes to display on the screen, even if
there's no problem. Hold down the "Cancel" button for three seconds, or
unplug the machine briefly to see if the code goes away. If it returns,
the problem is real.
The pump can also be the problem
Unplug the machine and remove the service panel. Locate the pump on the
floor of the machine, to the left of the tub, towards the front.
Inspect the wiring for burns, breaks or loose connections, and replace
as necessary. Use only appliance-grade wire.
TO REPLACE THE CONTROL PANEL.
If the wiring is fine, the problem is a severed relay on the control
panel. Unfortunately, this cannot be repaired and must be replaced.
Remove the control panel from the upper portion of the back of the
machine, and replace with an identical part from Frigidaire. Generic
parts can cause additional damage
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
