Question about LG ANWF100 Wireless dongle
Why doesn't lg an-wf100 work with apple airport extreme?
Blinking white light on apple airport extreme
Continual white blinks on Apple gear means an update failed, a resort is required, or the init test did not pass
Apr 03, 2012 | Apple AirPort Extreme (AIRPORTEXTREME)...
I have a RCA Digital Broadband DHG535-2 modem but my Apple Airport Extreme router does not work, any ideas on how to resolve this issue?
Apple uses airport for its wireless connection, how ever the device where you want to connect to should have the wireless feature embeded to it or you should have a wireless router to distribute the wireless signal, if you are using just a modem which doesn't have capability of distributing wireless signals, the Apple airport will surely not work for it requires a modem to connect to. you need to get a router and connect it in your modem so the Apple will work for wireless as well.
Dec 29, 2011 | Computers & Internet
Is too short for her MacBook Pro. -Thanks.
I would recommend purchasing a newer router that is more powerful. The Apple Airport Extreme is a fantastic router. If none of these choices work then you can either connect your Macbook via ethernet or move it closer to your router. here is the Apple Airport Extreme. http://store.apple.com/us/product/MC340LL/A/AirPort-Extreme?mco=MTY3ODQ5OTY
Dec 19, 2010 | Linksys WRT54G Wireless-G 802.11g...
Airport extreme stopped, front light dead, back lights flash
Your airport just died, contact apple support and request a replacement.
Jun 21, 2009 | Apple AirPort Extreme Wireless-N Wireless...
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
I want ot disable DHCP on apple extreme router. Because MS 2008 SBS R2 scans for DHCP servers and fails to config if found an other dhcp server (apple extreme)
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
Mar 16, 2009 | Apple AirPort Extreme Router
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Need to hook my airport extreme to a netgear switch and isnt working
Go to System Preferenced/Network and configure your new Airport Extreme card. Download and install the Airport Extreme Enabler from Apple in order to use the card in 802.11n mode. Reboot you Mac.
Oct 10, 2008 | Computers & Internet
LG ANWF100 Wireless dongle Logo
29 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
