Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
Why is my 42" toro ZT slow to react on the right side while turning?
Toro model 74182 ZT shuts off when you take parking brake off
Try eccelerating a little more before you take the brake off,
Apr 04, 2018 | Toro Garden
Have z4235 right control just stoped working left works fine any suggestion
There are adjustments for this problem on each side of machine. Just follow the arms and you will see. This happens due to vibration. GOOD LUCK FRIEND.
Apr 20, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
One side of mower wont turn
Your spindle may be seized. try turning the side by hand. Try moving it back and forth. If there is movement then your bearing in your spindle is bad. I f no movement than check under your deck to make sure nothing is stuck holding the blade from turning. You will probably have to replace your belt as well
Aug 06, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Can you jump start a toro zero turm mower with a car battery and jumper cables?
Better to not jump them can burn the leads up. Pull it out and slow charge it
Jul 17, 2014 | Toro NEW 42 TIMECUTTER 21.5 HP KAWASAKI...
One side move fine the other moves only when engaged slightly
may need an adjustment for the controls some mowers will do this at a slow idle if its hydrolic
Aug 18, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Cant turn toro time cutter to the right
You might want to post this question in the lawnmower section so that the proper expert sees it.
Sep 02, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Left side drive began to shake and rattle then gradually lost all function. Right side working fine.
each side has is own pump and drive motor check the fluid level and then you will need to remove it and either replace it or rebuild it
Jul 30, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Steering problem
ther should be a turn buckle to adjust them to the same speed
May 21, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
