Question about Sub-Zero 642
How to repair fan in subzero 201 - Sub-Zero 642
Freezer light in subzero model BI-36U won't go on
subzero are bad about the light switches going bad.... on most there are 2 switches one is for the freezer fan and the other is for the light... how to tell the difference is when u push the fan switch in the fzr fan will come.. the other one is for the light..... hope this helps.... ken
Oct 09, 2014 | Sub-Zero Refrigerators
How do I get the clean condenser to go off or reset?
This messages indicates excessive run times. The first potential cause is a dirty condenser, thus the message. But a bad condenser fan motor or loose fan blade could cause the same problem. Also, very warm room temperatures could cause extended run times. It could be a faulty control, although this is unlikely. A bad compressor or low refrigerant charge might be the cause. Beyond cleaning the coil or replacing the condenser fan motor or blade you will want to request a qualified technician to check the unit and make repairs. Certified SubZero servicers can be located by entering your zip code at http://www.subzero-wolf.com/contact-and-support/index.aspx
Sep 12, 2014 | Sub-Zero 680 / F
Subzero 3211rfd fan runs non-stop. I suspect it's using tons of power. Should this be happening?
No sir it should not! Your problem is more than likely your fan switch which can be found for purchase all over the web. Purchase a black back universal fan switch from somewhere and change the switch.
refer to this websites blog post on changing a light switch, onlu difference is you change the switch located right next to it. Switch replacement for sub zero.
thanks
-joe b
Mar 15, 2013 | Refrigerators
Subzero refrigerator condenser is makning clicking sound, it cools okay. It was first intermittent first and now continuous.
On a lot of Subzero models the conderser fan blade is plastic and the hub breaks,replacing the blade will stop the noise
Gene
Aug 02, 2011 | Refrigerators
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much...
your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Subzero refrigerator (20 years old!) compressor is noisy and the frame of the refrigerator is very hot.
Was able to get an Authorized Subzero company here this morning with NO emergency service charge. Turns out the fan needs to be replaced and it also needed freon.
Aug 03, 2008 | Sub-Zero Refrigerators
Refrigerators Logo
20 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
