Question about General Electric GHDA480N Built-in Dishwasher
GE Model GHDA480N00WW non-responsive
I presently have GE Model GHDA480N Dishwasher. The machine was working fine until about 2 weeks ago when it completely stop working. As per the instruction manual I cut the circuit breaker for about 2 min and turned it back on. The keypad is completed unresponsive only a the "normal wash" and "heated dry" stay on then after a few minutes they turn off and the machine is unresponsive to any function. I have checked to makes the lid is catching , but still no luck .What can the problem be ? the instrument panel? have you ever heard of this issue?
Im having the same problem with mine.. Did you find a solution
Posted on Mar 01, 2011
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
Is it possible to change the cover on the front of the Model GHDA48ONOOWW to another color?
Go to www.applianceart.com
These guys sell dishwasher covers for all dishwashers in many colors, textures, designs and stainless. They have custom options available too.
Worth checking out to give your dishwasher a new look.
May 15, 2011 | General Electric GHDA480N Built-in...
Water in dishwasher, will not pump out. Noise when machine is turned on
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 25, 2011 | Tricity Bendix 24 in. BDW53 Free-standing...
GE GSD500X-73BA great for 12 years; 2 weeks ago starts leaving film on all items; things don't seem clean; glasses foggy. Pumps in and out fine; water seems plenty hot; no air vent that I can see. What's...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | GE 24 in. GSD500X Built-in Dishwasher
Clean lamp blinking,
Try cutting the power fo 30 seconds, then press tne Reset button
Jun 24, 2010 | General Electric GHDA480N Built-in...
I have a 2007 GE top loader washing machine, model #wjsr4160g0ww. When the machine is agitating, it makes a very loud klunking sound. It was always a very quite machine until a few weeks ago. Nothing has...
The clunking is normal at the beginning of the cycle. The machine does a quick test to make sure the spline is in place before proceeding.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 24, 2010 | GE Washing Machines
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Ge phone answering machine
The solution for the base (not the handset) is to press and hold for 2 seconds the "Skip" button (it's marked with ">>").
Aug 27, 2007 | GE 25951EE2 Phone
General Electric GHDA480N Built-in Dishwasher Logo
390 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
