Question about Sony VAIO Computers & Internet
Sony Vaio PCG-41217L vpcsc LCD Flex - VAIO Sony Computers & Internet
SOURCE: driver for notebooks ony vaio pcg-c1xe
Dear Sir or madam
phease help me to get " multimedia controller' driver for notebook computer SONY VAIO PCG-C1XE ( windows xp)
thank you
best regards
NGUYEN HUU NAM
Posted on Aug 24, 2008
SOURCE: how to reformat my sony vaio PCG-7L1M
abcd
Posted on Sep 26, 2008
HW_Dude
  • 87 Answers
SOURCE: How Replace CMOS Battery in Sony Vaio VGN-FS742 / PCG-7D2L?
Here is are disassemble instructions for you,
Good Luck
Posted on Jan 11, 2009
SOURCE: I want to Down DRIVERS for Sony VAIO Version PCG-7L1M
jshajhva
Posted on Jul 22, 2009
  • 67 Answers
SOURCE: i have lost my webcam driver for pcg5k1l sony vaio
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGTR3AP1
Posted on Mar 05, 2010
Cant find drivers anywhere for Sony Vaio PCG-5A1M
http://www.downloadsarea.com/Free_sony-vaio-pcg-5a1m-drivers/
While I usually do driver downloads from CNet, this seems to be what you are looking for.
Apr 21, 2013 | Matsushita Sony Vaio PCG-5A1M 14.1in. SXGA...
REPLACE POWER JACK
http://www.ebay.com/itm/pcg-41217L-sony-vaio-DC-JACK-POWER-JACK-FOR-Input-Port-Socket-vpcsc-VPCEL-VPCF-V-/370628762815
Has two channels on the sides, to slide down into a channel formed in the outside edge, of the laptop Base Enclosure. (Bottom Cover)
Wires are soldered to it. Two of them. If there is a Red wire it goes to the Center terminal on the back of the jack. The Center hole is the Positive connection.
The Black wire goes to the outside terminal on the back of the jack.
(Negative)
Use good de-soldering/soldering skills. Do not make a cold solder joint. (Solder connection)
There are no exact Service Manuals listed for the Sony VAIO PCG-41217L Notebook PC. (It is also part of the VPCSC series. It is a VPCSC31FM)
However after you disassemble 100 laptops, or so; you find disassembly of all laptops follows a basic pattern.
http://www.ebay.com/itm/Sony-Vaio-vpcsc1afm-pcg-41217l-s-series-laptop-I5-blu-rau-MS-OFFICE-installed-/271101863505?pt=Laptops_Nov05&hash=item3f1eee2651
This shows me different key views of the laptop. I have also opened a separate window, with the User Guide from Sony eSupport.
The Ebay link shows detail of the Palm Rest Cover.
Shows it to be one piece with no separate Switch Cover.
(Switch Cover: Flat plastic strip above Keyboard, and below Display Assembly.
Usually has the Power On button, LED indicator lights, speakers, etc in it)
Also shows me a Bottom View.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Lay the notebook on a clean, static free cloth, on your table.
Helps protect the table, and the laptop from scratching.
Lay the notebook bottom side up, Battery Compartment facing away from you.
Use a multi-compartment container, and label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise DO NOT mix them up.
You should be wearing an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Average cost is around $3 to $6. Do not wear it, and/or connect to a good ground source, and when you are finished you can use your laptop for a doorstop.
Static 'kills' computers.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I feel an Anti-Static Mat is unwarranted.
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
You are going deep into the laptop, and the Static sensitive Processor, and other hardware components could be 'zapped'.
Use ESD wrist strap.
All screws are removed from the bottom of the laptop. All around the perimeter (Outside), and the inner ones.
The optical drive (CD/DVD drive) will slide out.
After the optical drive is removed, look to see if there are any hidden screws on the outside edge of the laptop, that may have been covered by the optical drive. Remove them if so.
Remove the Harddrive.
Remove the Ram Memory.
Remove all peripheral components. (Dummy PCI card, etc)
I don't know if the Palm Rest Cover removes on this model, or the Bottom Cover. (Base Enclosure)
Bottom Cover removal style,
http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-cs215j-laptop-replaciong-dc-jack-harness/
Yes. The bottom cover access panels are different than yours.
Posted for Keyboard removal, and Bottom Cover removal.
NOTE*
The Keyboard Cable STAYS attached to the Keyboard. It removes from the motherboard. There is NO plug connector on the end of the Keyboard Cable.
The Keyboard Cable is a FFC. Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
It ONLY plugs in, in one direction. Must go back the same way it was originally. Even if it was originally twisted.
For this reason you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector. (Sharpee?)
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two separate pieces, but DOES NOT come completely apart.
There is a larger rectangular Bottom part. This is the Body, and it is stationary. Mounted to the motherboard, and doesn't move.
There is a smaller rectangular piece on Top.
This is the Locking Bar.
There are two styles presently used;
1) This style slides. Slides up towards the LCD screen.
ONLY slides about 2mm. That is a little more than 1/16th of an Inch.
A) Closed, or can be said as Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
B) Open, or Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
The Locking Bar is barely seen on top, and the sides. The 'tabs' of it on the sides, are eased towards the LCD screen, with the thumbnails.
2) This style flips up,
A) Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
2) Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
IF, the Locking Bar is removed from the Body, it is broken; or the Body hinge pins are broken.
EITHER way means MOTHERBOARD REPLACEMENT, and why I am being so detailed. Use care.
Here is what the Keyboard looks like,
http://www.ebay.com/itm/SONY-PCG-41217L-Keyboard-Silver-/261121017591?pt=PCA_Mice_Trackballs&hash=item3ccc0686f7
Put your mouse in the middle of the photo, and slide to the right side of the Keyboard.
See that half-moon tab sticking out, that looks to have a threaded hole in it?
Screw comes up from the Bottom of the laptop, and goes into this tab.
Looking closer at the open laptop view of the Keyboard, it almost looks like the Keyboard is under the Palm Rest Cover, and cannot be removed until the Palm Rest Cover is removed.
May just be the view, or my eyes.
That is about as far as I can take you.
Post the problems you run into in a Comment, and we'll try to work them out together.
Regards,
joecoolvette
[ Just in case it will help,
http://www.insidemylaptop.com/category/7-sony-laptops/
Nov 11, 2012 | Sony VAIO Computers & Internet
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
Sony pcg-4f6p laptop lcd screen
You maybe able to get one from this WEB site.
LCD screens and Inverterswww.lcdparts.net
Jul 26, 2012 | Sony VAIO VGN-S460 Notebook
I need to replace my hard drive in my Viao PCG-GR370 laptop. Is it possible to put in a larger than 30 GB drive?
below is a link for a 320 gig hard drive for your model, i hope this helps
http://www.upgradecomputermemory.com/ram.cfm//memory/s/sony-vaio/sony-notebooks-vaio-pcg-series/VAIO-GR-PCG-GR-Series-Notebook/VAIO-PCG-GR370/320GB-Notebook-Hard-Drive-for-the-Sony-VAIO-PCG-GR370.html
Feb 14, 2011 | Sony VAIO GR370 Notebook
LCD turns white.
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. best regards
May 16, 2009 | Sony VAIO PCG-R505 12.1 in. Flat Panel LCD...
Dim LCD display
ccfl tube goes down or inverter cirucuit is fail
need to replace it
Feb 02, 2009 | Sony VAIO PCG-K23 Notebook
Computers & Internet Logo
20 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
