Question about Kenmore Washing Machines
Water will not enter washer after you turn on even though aggitator works
  • 351 Answers
Would check the water valve, first take the hoses off and clean out the screeens in the water valve if dirty if not i would probably change it first
Posted on Jun 23, 2009
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
I have a GE topload washer, I think the model # is WBSP1060T( there were three model # on the washer-VVSRV1040V & YVSR1040V were on there too) any way the water will not stop filling no matter what...
as to the filling issue this would either be the pressure switch or the hose that goes to the pressure switch to the tub has come off if you have any further questions message me back and please remember to rank this opinion it allows me to help others in similar situations Thanks Rick
p.s the starts agititating is normal when the lid closes it is engaging the lid switch
Mar 14, 2011 | GE WBSR3140D Top Load Washer
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
No aggitator movement
Set the timer for final spin and turn it on.
Does it pump out the water?
If the answer is yes, it pumps out water use this video to replace the direct drive coupling.
Apr 02, 2009 | Kenmore 22422 Top Load Washer
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Water in Barrel
sounds like a bad water inlet valve stuck open and permitting water to enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer filling up while turned off
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
