Question about Connex 4600 Base CB Radio
So im gonna have to get my own SWR meter to tune my antennas right?
    Genius:
  • Connex Master
  • 1,795 Answers
Not really.Many radios come with one built into the meter on the radio. For those with none you will need an external SWR meter. I would recomend a trucker 2000.
Posted on Aug 13, 2014
How do you tune cb radio 75wx st
Not sure what you mean by tune.
If you mean peak and tune, where in you increase the internal power output of the radio, then the quick and dirty way of doing it is, turn VR4 all the way to the left and take the tank slug out of L14. HOWEVER, I prefer to use a watt meter on avg power to adjust L14 to peak, and no more as not to over bias the final. But typically nothing will happen if you do. This will give you full modulation, and full carrier.
If by tune you mean, Tuning the SWR. Then that is a whole different topic.
In this case you don't actually tune the radio. You tune the antenna. If the antenna is not the correct length, relative to the wave length, Frequency of transmission..... then you will have a high SWR and this means more of your RF energy is not leaving the antenna, and going back into the radio. This is bad. this kills radios.
So to tune it you must make the antenna the right length. Here is how to check SWR.
Tune the radio to ch 20. Put the rf/SWR/CAL switch to CAL.
Turn the CAL knob all the way to the left.
Key the radio, and turn the CAL knob to the right until the needle of the meter is at the CAL mark, on the top line of the meter indicated by a little upside down triangle. That is the cal mark. The needle should be on it.
Flip the RF/SWR/CAL switch to SWR while holding the key down.
The meter is now showing your SWR. If it is under 2 you are not real good, but not gonna kill the radio. If you are 1.5 or less you are good to go. Ideally you want to be 1.5 or less if you can.
If it is over 2 you should try to get it lower.
here is how to find out if the antenna is too long or too short.
Turn to ch 1, repeat the steps to check SWR. Then do the same thing on ch 40. Compare the reading. If the reading is higher on 1 then on 40 the antenna is too short, and you need to make it longer. If it is higher on 40 then 1, it is too long and you need to make it shorter.
All antennas have a way of adjusting the length.
Hope this helps.
Aug 10, 2012 | Radio Communications
It says cb atanna warning when i key the mic. i have a new cable and new atannas as of 20 min ago. what is the problem
The problem is you need to tune the antenna.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Aug 10, 2011 | Cobra Radio Communications
Got it peaked and tuned and hooked up a new coax and mirror bracket and my swr is at 4. Before I did all this I had the stock coax and swr was under 2. What do I need to do to get the swr down?
The antenna needs to be tuned. The reason all of a sudden your SWR is a 4 when it used to be a 2 is, after a peak and tune, the radio is putting out more power, there for more RF energy is being reflected back into the radio. That is why the antenna has to be tuned.
1. Turn to CH 1
4. Turn to CH 40.
Nov 17, 2010 | Cobra 29 LTD CB Radio
I don't understand how to adjust the SWR or how the built in meter works for my DX949.
Here is a basic instruction on how to adjust the SWR. When you adjust the SWR, you are not changing anything on the radio. You are actually tuning the antenna for best SWR. The lower the better. SWR stands for "Standing Wave Ratio" Or in layman's terms, SWR is energy that is reflected back into the radio. The higher your SWR reading, the more RF energy that is not leaving the antenna, and getting reflected back into the radio. This can cause damage to the transmit section of the radio. The length of the antenna is what will change this. The length of the antenna must match the length of the radio wave. The following instruction will explain how to take an SWR reading, and how to use that reading to ascertain weather the antenna is too long or too short.
Here is a quick explanation of the meter. There are 3 settings for the meter. SWR, MOD, and PWR. When you are not keying the radio the meter will show you your receive signal. How strong some ones signal is. When you have the switch on MOD and key, when you talk it shows you modulation. How much audio you are putting through the radio. When its on power, and you key the radio, it shows you your dead key wattage.
Tuning your antenna:
2. Switch the meter switch to SWR
1. Turn to CH 1
4. Turn to CH 40.
Nov 16, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
I need to know how to tune my cb radio. I have a Cobra 19DXIV and I can only hear certain people and they have to be within 50 feet. I also need to be able to hear the people close to me and people that...
1. Turn to CH 1
4. Turn to CH 40.
Nov 15, 2010 | Cobra 19 DX IV CB Radio
I just got a cobra 29ltd army edition and i cant get the SWR right
Takes some time to get it down if you are new to it. Here is a step by step instruction on setting it.....
1. Turn to CH 1
4. Turn to CH 40.
Nov 12, 2010 | Cobra 29 LTD CB Radio
Im having a problem with people hearing me on my CB. I can hear people fine and it comes in real clear, but they can't hear me at all, i mean they can but its just that its so low they can hear me. It was...
Tune your antenna. If he took the metal whip out of the base, then he messed the tuning all up.
1. Turn to CH 1
4. Turn to CH 40.
Nov 12, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cobra 150 gtl dx cb radio. my reception and transmition is not at peek performance. can you help me please? i have tried everything i know to do.
If this radio has been peaked and tuned already, and it is not in need of a full alignment, then it's most likely the antenna.
Your antenna is everything. You need a good antenna, and it needs to be tuned to the lowest SWR.
1. Turn to CH 1
4. Turn to CH 40.
Oct 20, 2010 | Cobra 150 GTL DX Base CB Radio
WHEN I TAKL HAVE DISTORTION MY COBRA IS CB COBRA 19 ULTRA 111 BUY NEW. SOME PEOPLE SAY YOUI ARE OUT OF FQ.
your not out of frequency. Your antenna is not tuned.
  1. Turn to CH 1
  4. Turn to CH 40.
Jun 21, 2010 | Cobra Radio Communications
Radio Communications Logo
48 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
