Question about Vehicle Parts & Accessories
How to change transfer case on a 2007 escape - Vehicle Parts & Accessories
    New Friend:
  • 113 Answers
Buy a HAYNES manual for your car. it's in there.
Posted on Nov 26, 2014
Transfer case problems
    2007 Dodge Nitro Recalls - Cars.com
    www.cars.com/recalls/dodge/nitro/2007/
    Cars.comLook up all NHTSA vehicle safety recalls for your 2007 Dodge Nitro, and contact ...THE TRANSFER CASE HEAT SHIELD MAY DROP DOWN AND RUB ON THE ...ADDITIONALLY, THE DRIVE SHAFT FAILURE WILL RESULT IN A LOSS OF ...
    Differential and Transfer Case ' Dodge Nitro Forum
    www.nitroforumz.com > ... > Detailing and General Maintenance Forum
    Jul 24, 2010 - Vehicle: 2007 Nitro 4X4. Trim: SLT. Color: Black. Found this while searching for instructions on Front/Rear Axle and Transfer case fluid changes ... transfer case leak
    Aug 21, 2014
    Front Axle CV Joint
    Nov 24, 2013
    Leaky Transfer Case
    Oct 4, 2011
    More results from www.nitroforumz.com images for 2007 Dodge Nitro Transfer case problems
Jan 27, 2016 | 2007 Dodge Nitro
How do I change the transfer case fluid on za ford escape
CAUTION
New transfer case lubricant must be installed any time the transfer case has been submerged in water. Also, transfer case failure CAN result if the correct fill procedures are not followed.
NOTE: The transfer case is lubricated for life and is not to be checked unless a leak is suspected or a repair is necessary.
  1. Remove the drain plug and drain the transfer case.
  2. Apply sealant to the drain plug threads and install the plug.
  3. The fluid level must be even with the bottom of the filler hole with the vehicle on flat, level ground.
To Fill:
  1. Remove the fill plug and fill the transfer case with SAE 75W-140 synthetic gear lubricant.
  2. Apply sealant to the fill plug and install the plug.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you
Jul 31, 2011 | 2003 Ford Escape
I want to replace my transfer case for a 2006 Ford escape. Can you tell me or give me so information how to do it
You need to raise the truck off all four wheels the remove the rear drive shaft then remove the front drive shaft .Next drain the fluid from the transfer case . next reinstall drain plug. Now use a jack and a flat piece of wood and slightly jack up un the bottom of the transmission to take the weight off the crossmember . Next remove the croosmember brace after removing that and supporting the transmission you can start removing the wiring and contols on the transfer case after dissconecting all that now you can remove the bolts from the transmission to the transfer case , remove all but one easy to get to lower one ( you choose) now start taking the last bolt out while holding the transfer to the transmission .( two people here helps) once you have removed the last bolt slide the transfer case back torwards the rear end some fluid may come out once you seperate these two be ready to catch it with a drain pan . you slide the transfer off the transmission out put shaft and it out . flow the step inreverse to install don't forget to refill the new transfer case with fluid and check the transmission fluid level once you have lowerd the truck back down.
May 15, 2011 | 2006 Ford Escape
Yesterday I look my car to the local dealership for an oil change, and they told me that I had a leak around the transfer case. Said it was an "O" ring. The parts are going to cost $50, but...
YES, iT IS HARD TO GET TO AND THEY HAVE TO PULL THE WHOLE TRANSFER CASE TO GET TO IT.
YOU COULD GET IT DONE CHEAPER BY A SHOP THAN THE Dealer. Maybe a couple hundred less.
Feb 24, 2011 | 2005 Ford Escape
How do I change the transfer case oil on a 2007 stratoliner?
Hi, Craig_vogl for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Transfer Gear Oil Change REALLY
Stratoliner 09 transfer case and oil drain plugs
Yamaha XV19SW Service Manual
OEM parts for Yamaha
Yamaha ROADLINER XV19SW Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 11, 2010 | 2007 Yamaha Stratoliner
I want to change the oil in the transfer case on my 06 ZC Ford escape but canot finde the drain plug it is not where it shown in the Hayns service manual
i think you have to drain the gearbox which will drain the transfer case,if your not sure then leave well alone because it may have to be sucked out through the filler plug with a special tool part number so and so
Apr 17, 2010 | 2006 Ford Escape
4x4 transfer case oil change for 2007 Chevy Tahoe
Go buy the chevrolet shop manual for the truck. Its worth every penny in the long run and will save you thousands by not going to the dealer for everything, because they consult the shop manual. make sure your tranny doesnt share fluid with your transfer case, you could over fill or underfill it easily.
Jun 03, 2009 | 2007 Chevrolet Tahoe
2007 quadratrac transfer case
They run on the same fluid but have different fill ports. The transfer case has a fill hole on the back of the case. The fill plug is a big looking nut. Fill the case from there on a level ground until the fluid starts to come out, then it's full.
Jan 08, 2009 | 2007 Jeep Grand Cherokee Overland
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
