Question about Bosch Tassimo TAS4511UC Coffee Maker
How do i take apart a bosch tassimo tas451? - Bosch Tassimo TAS4511UC Coffee Maker
2 Suggested Answers
  • 5382 Answers
SOURCE: how much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Posted on Apr 25, 2012
Bosch tassimo coffee maker What is the yellow disc for where you place the coffee pod? Also what is the digital piece on the lid for? If for size of coffee cup fill , how do you adjust it?????
Hi The yellow disk is used when cleaning the coffee machine and the size for cups is usually on the tassimo pack at the back.
The "digital piece" is a bar code for the discs.Hope that helps? ps,
Go to Tassimo site for info
Feb 05, 2017 | Bosch Coffee Makers & Espresso Machines
Why does my Tassimo stop and flash refer to user manuel which I haven't got
If you put Bosch Tassimo user manual into Google you will be able to get download and print off a manual.
Mar 12, 2016 | Bosch Tassimo T65
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
My tassimo coffee machine doesn't work.
Call this number for recalls;
(855) 843-2487
If any of these Model #'s pertain to your's, you can get a new one from the Company. Hope this helps, let me know!
TAS100
TAS200 TAS451 TAS46 TAS651 TAS6512CUL
Oct 08, 2014 | Tassimo T-Discs: Gevalia Dark Italian...
Descale T20 Bosch Tassimo
you need to use the cleaner disk (tucked into the back of the machine) and run through some of the cleaner solution. Then run though just water. Don't forget to store the cleaner disk back in the machine.
Sep 09, 2014 | Bosch Tassimo T20 Single Serve Brewer,...
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it ยท Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Tassimo low water light will not reset
The problem is because Tassimo water tanks have a floating magnet in them which operates the water level switch inside the body. The magnet gets weak over time. Replacement tanks cost too much to be worth the cost. The simple answer is to stick a fridge magnet on the back of the unit (just above the power switch) using blue tack or similar (you can experiment to find the right position). Our unit has been working fine like this for a few years now. :-)
May 24, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Tassimo coffee maker part replacement
If your machine is made by Bosch then go to www.bosch-eshop.com where you can order spare parts online. I think the part number is 616231:Jet and is called a Tassimo piercing unit.
Nov 20, 2009 | Braun Tassimo Espresso Machine/Coffee...
Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
Oct 06, 2009 | Bosch Coffee Makers & Espresso Machines
Bosch Tassimo TAS4511UC Coffee Maker Logo
112 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Donald Currie III
Level 1 Expert
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
