Question about Xerox WorkCentre Pro 90 Copier
NVM backup file WCP 255
I change nvm battary without backup) and after that it's always jam paper 08-100. I sure that will fix only by mrd disk or nvm file, if any bady have this backap file please help
The Machine
  • 788 Answers
SOURCE: 3535
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Posted on Jun 24, 2008
Arius
  • 446 Answers
SOURCE: 9-358 error is there a reset nvm
no! there isnt, you need to replace this in order to reset the info inside, you can refresh the nvram but the info is still there
Posted on Sep 22, 2008
  • 8 Answers
SOURCE: NVM settings
In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
Posted on Dec 29, 2008
zeroxparts
  • 15 Answers
SOURCE: I have a EX-3535 fuser error code 004-361 coming
4-361 Drum Motor
Drum Motor failure.
Initial Actions
• Remove all Drum Cartridges.
• Perform REP 1.6.
Procedure
The machine is a DC3535.
Y N
Enter dC330 [004-003] and press Start. The Drum Motor energizes and the drives
rotate.
Y N
Go to Figure 1 of this procedure and measure voltage between the Drum Motor P/
J210-4 (+) and GND (-). +5 VDC is measured.
Y N
Go to Figure 3 of the +5 VDC Wirenets and troubleshoot the problem.
Replace Drum Motor (PL 1.1).
Posted on Dec 01, 2009
Testimonial: "Excellent Diagnosis - I was wrong about the fuser and it was one of the drums very stiff so I changed it and all is well. Thanks"
SOURCE: Hello, after a NVM reset my ADF stop working.
Sorry to ask bu how did you enter NVM or better how do you reset nvm plz reply !!!
Posted on Feb 24, 2010
Fault code 42-326 xerox work center 7655 the printer not print all time i have massage system fault
Hello, i sell the pws laptops, this is the complete list of all the printers that it have installe:
EDOC BROWSER (OMNI BROWSER)
-1010 DIAGNOSCTICS
-1065 NVM TOOL
-1090 NVM TOOL
-2101 DIAGNOSTIC
-4110 PWS DIAGNOSTIC TOOL
-4112/4127 SW TOOL
-4590 PWS DIAGNOSTIC TOOL
-4594 PWS DIAGNOSTIC TOOL
-5065 NVM TOOL
-5090 NVM TOOL
-5100 NVM TOOL
-5100 ELECTRONIC SERVICE LOG
-5365 NVM TOOL
-5800 ELECTRONIC SERVICE LOG
-5800 CALL FLOW
-5800 NVM TOOL
-6100 SCP, CONFIG DB
-6135 SCP,CONFIG DB, SCP
-6180 SCP, CONFIG DB
-700CP, NVM ACCES/SW TOOL
-D135 NVM TOOL
-DC2045 EPC DIAGNOSTIC
-DC2060 EPC DIAGNOSTIC
-DC220/230 ALTERNATE BOOT, DATA MAN, ELECTRONIC SERVICE LOG
-DC2240/1632 DIAGNOSTIC
-DC332/340 ALTERNATE BOOT
-DC332/340 DATAMAN
-DC332/340 ELECTRONIC SERVICE LOG
-DC3535 DIAGNOSTIC
-DC420/440 ALTERNATE BOOT
-DC420/440 DATAMAN
-DC420/440 ELECTRONIC SERVICE LOG
-DC5000 PWS DIAGNOSTIC TOOL
-DC5252 EPC DIAGNOSTIC
-DC6060 EPC DIAGNOSTIC
-DCS20 SOFTWARE UPLOAD
-DCS20 TTY
-DCS35 2 X 40, SOFTWARE UPLOAD, TTY
-DCS40-65 ALTERNATE BOOT, DIAGNOSTIC, ELECTRONIC DOCUMENTATION, ELECTRONIC SERVICE LOG
-DOCU NVM TOOL
-DOCU12 DIAGNOSTIC
-DOCUCOLOR 242/252/260 SW DOWNLOAD TOOL
-DOCUCOLOR 250 PWS DIAGNOSTIC TOOL
-DT135 NVM TOOL
-DT65 DP65 SCP,CONFIG DB, DIAGNOSTIC, DOCUMENTATION, ELECTRONIC SERVICE LOG
-WORKCENTRE 7132 SW DOWNLOAD TOOL
-WC 7232/7242 SW DOWNLOAD TOOL
-WC 7346 SW DOWNLOAD TOOL
-WC 7328/7335/7345 SW DOWNLOAD TOOL
-WC M24 DIAGNOSTIC
-WCPP DIAGNOSTIC
-XC550_560 NVM ACCES/SW DOWNLOAD TOOL
-PRODUCT UPDATE LINKS:
-EFILE DOWNLOAD INSTRUCTIONS
-MY PRODUCT UPDATE LINKS
-BUSINESS READY FINISHER
-COLOR C60,C70 PRINTER FAMILY
-ENGINEERING SYSTEMS,721P,6622,8855
-ESPRESSO BOOK MACHINE
-MISCELLANEOUS
-VERSANT 2100 PRESS FAMILY
-WIDE FORMAT IJP 2000
-WORKCENTRE 5890 FAMILY
-WORKCENTRE 5945,5955 FAMILY
-WORKCENTRE 7220,7225 FAMILY
- WORKCENTRE 78XX
my whatsapp is +52 1 664 133 7404
I accept paypal.
Oct 26, 2016 | Xerox WorkCentre 7665 Copier
Paper james at the fuser, i replaced the fuser but it still jams
Try resetting the nvm settings (Pag 3 of the attach PDF under Support Menu >> Service tool Menu) And the next time you try to print configure correctly the paper settings on the printer and on the print driver. Please make sure your are configuring the paper weight correctly so that the fuser applies the right heat and pressure.
Aug 30, 2010 | Xerox Phaser 7300DN Laser Printer
PSC 2310
To resolve this issue please perform the steps given below.
Perform NVM Reset:
1.Disconnect the power cord without turning off the unit.
2. Wait 60 sec.
3. Press and Hold OK and Cancel buttons while plugging in the power cord into the wall outlet.
Aug 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
How can I change voice in my Sanyo EasyStreet NVM-4370 Car GPS Receiver -
NVM-4370 shipped with one voice per language therefore you will not able to do so.
Main Menu -> Settings -> Language.
Apr 05, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Video input won't work on NVM-4370
Go to Settings and enable the feature first. Once it's enabled the option will become usable.
Mar 10, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
SD card can not be accessed on Sanyo NVM-4370
Did you hear a beep when SD card is inserted? Did you also try to hard reset the unit using the On/Off switch located at the bottom of the unit? Try with another SD card and see if the SD option is selectabe. If all have tried I suggest you to exchange for another unit. HTH.
Mar 02, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
My sanyo nvm 4370 video option say no video player installed
This unit only supports MPEG4/H.264 file. The files format has to be .MP4. This unit cannot play all MPEG4/H.264 movie files. Most movies out there are converted using DivX or XviD codec so if you need to convert them to this supported format. It will mostly cost you time if you found a free converter.
If you don't have time. You might try my basic hack to add a 3rd party media player that will play almost everything out there and it also supports sub-titles. You can check out my video on YT @ http://www.youtube.com/KhaKev.
Feb 11, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Xerox 5760 Color Copier has fault 03-302 at start-up
Xerox 5350, 5352, 5760 Code Description 00-009, 030, 031, 032, 033 A door was opened while paper was being fed 00-047 Paper in duplex 00-1 Auditron 00-2 Diagnostic error 00-3 Faults error 00-4 Ric error 00-5 Job manager system error 00-6 LLM interface 00-7 Standby error 00-8 Communications error 00-9 Xerographic error 01-300 Front interlock 01-310 Right upper interlock 01-315 Left upper interlock 01-320 Left lower interlock 01-325 Fuser interlock 02-910 Key counter missing 02-920 Wrong combination of accessories 03-302, 321, 322, 326, 327 LLM to ISIL communications problems 03-328 IOT communications problem with duplex or tray 4 03-330 IOT communications problems with HCF 03-335, 336 LLM communications problems with edit 03-340 NVM memory 03-341-347 Communications problems between IOT and sorter 03-350-354 Communications problem with LLM and user interface 03-363, 364 Communications problem between LLM & optics 03-370-03-373 Communications problem between LLM & DADF 03-380, 384 03-416-422 RAM memory problem 03-424, 426 NVM memory problem 03-430, 432 Billing problem 03-439 GRAIB communications problem 03-440 RIC communications problem 03-441 RIC NVM problem 03-442 Modem 03-443-458 RIC problems 03-460 Serial communications processor problem 04-300 Main motor or drive problem 05-100-108 DADF registration sensor 05-110 DADF exit sensor 05-115, 120 DADF jams 05-305 DADF document drive 05-310, 312 DADF document sensor 05-316 DADF registration sensor jam 05-325 DADF exit sensor 05-335, 341, 345 DADF interlock switches 06-300-310 Scan problems 06-315 Scan drive 06-320A, 320B, 320C, 325 Scan problem 06-330 Lens drive 06-340 Exposure control problem 06-342 LLM CPU problem 06-344-350 Exposure cvontrol problem 06-352 IOT CPU problem 07-300, 315, 330, 345 Tray faults 07-360-370 HCF problems 07-375, 380A, 380B Duplex problems 08-100-110 Feed problems. Lead edge of copy paper is late getting to feed sensor of tray 1 08-115-162 Feed problem. Lead edge of copy paper is late getting to registration sensor 08-165 Paper jam at registration sensor 08-310-370 Paper at a sensor when power is turned on 08-330 DADF nudger sensor 08-380 Registration side to side problem with home position 08-390 Nip 09-300 Copy cartridge finished (drum unit) 09-310 Add black toner Add color toner 09-320 Add color toner 09-330 Wrong copy cartridge (wrong drum unit) 09-340 Drum cartridge not installed properly 09-350 Waste toner full 100 A fault has occurred 10-100 Exit jam 10-105 Exit jam 10-110 Vertical sensor jam 10-120, 122, 125 Duplex jam 10-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 10-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 10-310 High fuser temperature 10-312 Fuser not up to temperature after energy save 10-314 Fuser problem 10-320 Fuser web finished 10-330, 335, 340 Exit switch, vertical sensor switch actuated when power is turned on 11-100-116 Sorter jam 11-150-176 Sorter auto stapler jam 11-310, 314, 316 Sorter interlock 11-325A,B,C,D,E,F,G Sorter index 11-352, 354, 356 Sorter auto stapler interlocks 11-365A,B,C,D,E Sorter auto stapler bin 11-370,371,372A,373A,373B,374 Sorter auto stapler staple failure, staple home problem or tamper home problem 11-385A,385B,390A,B,C,D,E,396A Sorter auto stapler staple failure, staple home problem or tamper home problem 301 Fuser web must be replaced 302 Copy cartridge (drum unit) must be replaced 501 Tray 1 must be rebuilt 502 Tray 2 must be rebuilt 503 Tray 3 must be rebuilt 504 Tray 4 must be rebuilt 505 HCF must be rebuilt 506 Bypass must be rebuilt 507 Duplex unit must be rebuilt 508 Replace black developer 509 Replace red developer 510 Replace green developer 512 Replace brown developer 513 Copy cartridge (drum unit) will need replacing soon 514 Fuser web will need replacing soon 515 DADF belt should be replaced 516 DADF feed rollers should be replaced 517 Replace exposure lamp 518 Replace suction filter 519 Replace ozone filter 520 Replace optics filter 521 Replace particle filter 522 Replace upper fuser roller 523 Replace fuser pawls 524 Replace pressure roller 525 Replace pressure roller pawls 900-905 Key operator calls
Jan 16, 2009 | Office Equipment & Supplies
Can't change .wav files on Sanyo NVM-4370 GPS
Jack tell me more about your Prob. I might have a solution.
Dec 28, 2008 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
