Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
How to remove Whirlpool EV160NZTQ drain pan - Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
Buildup of ice on bottom (inside) , drain tube in pan underneath but is always dry.see no reson for ice build up
The drain pipe is most likely blocked. It is a plastic tube about 10mm diameter, as you've probably noticed. Try reaming it out gently with a wire hanger.
Sep 06, 2010 | Whirlpool 247 cu. ft. Upright Freezer...
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Sometimes water comes out everywhere all over the floorand on the inside, now everything freezes inside the firdge
behind the freezer inner wall is a tube that leads down to a pan under your refrigerator it is blocked: remove the wall; remove the ice buildup on the evaporator coils then using a funnel pour hot water through the tube to the pan. be sure to empty the pan when you are done
Sep 05, 2009 | Whirlpool Freezers
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Freezing water line
Yes this freezer is built by woods corp. They had a myriad of drain icing problems. There is a kit to resolve this although sometimes it doesnt always work make sure that the plastic liner in the drain trough isnt cracked or it will let water in the liner, icing the drain. Seal any cracks with epoxy. Try running a piece of 14 guage copper wire strand (no insulation) from def heater and extend into drain hole. This will help it drain. All this is axcessed though back cover in freezer.
Oct 05, 2007 | Freezers
Freezers Logo
100 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
