SOURCE: Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
SOURCE: I have a Scotts Rotary Spreader model C2.\r\nIt
There is no correlation between the letters on your C2 to the numbers that are now used on newer spreader models. Your best bet is to do your own test. Measure a 50 x 20 foot area in your lawn. Place enough material in your hopper to cover 1000 sq ft. Set your spreader setting on a ¼ of your spreader setting range. Spread the material over the 50 x 20 foot area. If you have product left over you increase your spreader setting. If you come up short you decrease your spreader setting. While this is not exact it will give you the ballpark setting
SOURCE: I have a Scotts Basic
Start with #3 setting. You will be fine I have same spreader.Good Luck..
Testimonial: "Thank you for the help. I had pretty much settled on the 3.25 setting after reading the back of a Scotts Turfbuilder 17 lb. bag of similar ingredients"
SOURCE: I just bought a new
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
SOURCE: I have a new Scotts Classic Drop spreader and an
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
