Question about Mitutoyo Measuring Tools & Sensors
My mitutoyo 505-675 dial caliper is resting at 3:00 rather than 12:00. How can I adjust? It is a newer model.
  • 520 Answers
Turn the outside dial to any desired number you chose
Posted on Jul 01, 2009
How do I change the battery in a digimatic model # cd-6
In mitutoyo digital vernier battry inserted upper portion side by display you battry cover theire is an arrow mark downward release you will find battery in side remove it and put new one battery code Sr 44 you will from marketor in mall try it
Oct 17, 2012 | Mitutoyo Dial Calipers
I HAVE A MITUTOYO 6 INCH ELECTRONIC CALIPERS,MODEL # CD-6 CS. IT NO LONGER CAN SET ITSELF TO ZERO WHEN THE JAWS ARE CLOSED AND IN THE ZERO POSITION. PRESSING THE ZERO ABS CODE FOR 2 SECONDS AND THE...
The answers above by Kerry Littleton have nothing to do with our calipers. The answer above by Bob Pulver is well-intentioned but doesn't address the real issue.
The real issue is the ORIGIN button is little-used and a bit reluctant to "make". The solution is to use a blunt plastic probe to REALLY PUSH down the button and hold it. The caliper will reset to zero.
Dec 24, 2010 | Mitutoyo Dial Calipers
The face on my dial calipers is turned 90 degrees to match up to 0. How do I adjust it to be correct and readabel?
There should be a small set screw you can loosen by hand and adjust the face of the dial to zero with the jaws closed....this is typical of most calipers...it allows you to zero the dial on a given thickness of material and only read variations based on that thickness.
Take care.
Dec 09, 2010 | Mitutoyo Dial Calipers
How do you rezero a 505-637 mitutoyo dial caliper
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
Dec 03, 2010 | Mitutoyo 0 150mm X .02mm Dial Caliper
My caliper is .030 off of zero I don't know how this happened . How can I fix this problem
Just loosen the screw that clamps the dial in place, close the jaws, and turn the dial to zero. Then tighten the screw clamp
Sep 18, 2010 | Mitutoyo Dial Calipers
How to reset zero position reading on a mitutoyo 505 629 dial caliper?
unless they have changed them there is asrew like a watch winder on the dial it self ,undo it slightly and turn the dial to the desired position then retighten the screw
Nov 08, 2009 | Mitutoyo 505 677: Test & Measurement...
RESETTING THE SPRING LOAD IN CALIPERS
Slide-wear adjuster screws are located on top of the movable readout head. They are quite tiny and require VERY little adjustment. May take several attempts to get the "feel" of drag that you like, but repeatability can be "dead-nuts" when adjusted correctly.
Hope this helps,
Dolf-
Oct 16, 2009 | Mitutoyo 505 677: Test & Measurement...
Adjusting the angle of the contact point on a Mitutoyo 513-402
By simply pushing it (the contact point), it may be stiff to start but should ease up over time. Remember if your doing precision work (0.001mm or seconds of a degree) changing this original position will affect your reading so refer to booklet within original packaging or visit mitutoyo website's (Japan, USA, UK) between them they have most instructions available it's just a question of finding it, Good Luck.
May 09, 2009 | Mitutoyo Dial Indicator-Graduations:0....
Measuring Tools & Sensors Logo
835 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Dragan Manojlovic
Dragan Manojlovic
Level 1 Expert
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
