Question about Samsung SCX Office Equipment & Supplies
Paper jams before entering the fuser
It's a Samsung SCX-4300, the paper always jams, it prints but does not reach the fuser
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Possible cause
bad paper pikup-check roller, separation pad, check toner cartidge , is t moving tight?
last fuser
Posted on Oct 02, 2015
SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Posted on Feb 04, 2008
anjana03
  • 361 Answers
SOURCE: The Samsung scx 4521 printer JAM
ithink it is a hard were pr oblem we should clean our printer time by time, there is many dust inside, they can make disattacment between sencer and parts ,so we get this information. open printer and also if u open drom and other part open , then blow air by air blower machin e.we solve more than 80% thise type case in our lab .
Posted on Jun 19, 2009
xptareq2000
  • 1447 Answers
SOURCE: how to reset samsung scx 4300 printer cartridge
you can not reset this chip change it you must be buy a new one cartridge
Posted on Nov 04, 2009
SOURCE: samsung scx-4300 jam 1 or install toner problem
Maintenance > Of clear Of setting > Of all Of setting [OK]
In the service menu (TECH MODE):MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
MUSTAFA BULENT KILIMCI
YUNUS COMPUTER CEO
COMPUTER EXPERT
e-mail & msn : address mbkilimci@yunuscomputer.com
Posted on Jan 07, 2010
SOURCE: samsung scx-4300 toner exhausted
samsung scx-4300 error message "toner exhausted" how to reset printer
Posted on Jul 11, 2010
Paper jam 2 error in scx 4321
is this there all the time or only when you try to print? if it is there all the time there is a paper jam in the fuser area the back of the machine. if it only happens when you try to print it is most likely the feed tires in the paper feed in area.
Sep 29, 2014 | Samsung SCX-4321 All-In-One Laser Printer
What causes three black blotches to appear on the right hand margin of documents printed on our SCX-4300?
TO REPLACE YOUR PRINT CARTRIDGE. IF THAT DOES NOT WORK IT IS YOUR FUSER UNIT AND YOU WILL NEED TO TAKE IT TO A SERVICE CENTER
Jul 15, 2014 | Samsung SCX-4300 Monochrome Laser...
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Sir my sumsung scx 4300 is jamming on the fuser unit
Verify the sensor actuator and the gears,is a mechanical problem.
Mar 07, 2013 | Samsung SCX Office Equipment & Supplies
Samsung SCX-4300 paper jam
sir i have samsung scx 3201 printer but paper loading problem so plz solloved my problem
Oct 23, 2012 | Samsung SCX-4300 All-In-One Laser Printer
How to solve paper jam problem in samsung scx 4300 printer
This is the problem with the paper feed mechanism. make sure nothing obstructs the paper path. also, check the feed roller - this is the rubber thingy that picks up the paper, make sure it is clean and not gummy.
if the paper does not enter the printer squarely, then the printout will be crooked. if it is severely misaligned, the you will have a paper jam.
OR
the fuser gets too hot which causes problems with the paper or the toner.
hope this helps..
Jan 06, 2011 | Samsung Office Equipment & Supplies
Sir we want asoftware to reset toner cartridge
there is no software for reset toner go to the tech mode
it wil help you
Jan 14, 2010 | Samsung SCX-4300 Monochrome Laser...
Jam 01-009 code from my Samsung SCX-6345. It always jam at the fuser unit please help.. thanks..
Probably have a scrap paper stuck in the fuser or a "stripper finger" out of place, catching the paper. You'll need to remove the fuser to get a good look at things.
Aug 04, 2009 | Samsung SCX-6345N Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
I have samsung scx-4300 printer this time show toner error
good day sir, these are the possible causes of toner errors of samsung scx. You can check all this causes.
  • You have used an unauthorized cartridge.
  • the toner cartridge is not installed.
  • Paper has jammed in the fuser area or in the fuser manual feeder.
  • The toner cartridge has run out.
  • the toner is almost empty.
  • To prevent serious pollution of breakdown of printer, the printer stops printing.
  • the toner cartridge is not a samsung genuine cartridge.
hope this will help you. god bless.
Mar 24, 2009 | Samsung SCX-4300 Monochrome Laser...
71 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
