Question about Magellan RoadMate 800 GPS Receiver
My Magellan roadmate 1700 doesn't open completely ,how can I fix it?
It starts to open,but stop working
    Sergeant:
  • 435 Answers
I had to send my 1700 back, contact magellan & see what they say
Posted on Feb 13, 2015
montecarlo
  • 50 Answers
SOURCE: Magellan Roadmate 800 freezes
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
  • 5 Answers
SOURCE: my magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Posted on Dec 18, 2009
My magellan 1700 won't turn on, even after I reset it and put in a new battery
if you have a volt ohm meter see if theres voltage at the power adapter plug
May 12, 2014 | Magellan RoadMate 2000 GPS Receiver
Can you download philippines map to madgellan roadmate 1700 gps?
Visit the website of Magellan for your country or their global site. Find the maps, pay for them and download to your computer. You will have access to the installation instructions. Usually you install some software by Magellan, you connect your device to your computer and the proprietary software will install them on the GPS.
Mar 18, 2014 | Magellan RoadMate GPS
Loading a philippines map
Mar 17, 2014 | Magellan Roadmate 2120T-LM GPS Vehicle...
I just bough a madgellan 1700 roadmate gps. i need to know if i can load it with philippines map?
Mar 17, 2014 | Magellan RoadMate 1700 GPS Navigator
My Magellan Roadmate 3045 is not getting any signal. I turn it on, and it doesn't even attempt to acquire a signal. The satellite icon in the top right-hand corner of the menu which indicates signal...
Mine actually stopped working the same day you posted this. How strange is that? I have not been able to figure out what is wrong with it. Have you figured out a solution?
Aug 06, 2011 | Magellan Roadmate 3045 - uses Gomadic...
After dowloaldin and then uploading an update for my Magellan roadmate 1700, iwas instructed to reset the unit and allow it to reboot. All I get now when I power on is the reboot screen and it never starts...
tim if you havent already sent your unit into magellin i have a 5 min fix for you.
1) plug in your magellin
2) when the auto play option pops up on your computer, click open folder to view files
3) double click the app folder
4) find FirmwareReleaseVersion.dll and delete it.
now just simply unplug your roadmate 1700 reset it and plug it back in to your compter and re download the updates. you will start with version 2.77 then version 3.11 and it should work.
josh
Oct 03, 2010 | GPS
Magellan RoadMate not Working
Common problem Herbert, Unfortunately, it's a common problem that can be fixed by having several dead units lying around to take parts from. So, if you can find a unit to salvage from, then do that and change out the LCD. if you can't.. then I'm sorry Herbert but there's not much else you can do. Try reloading the software if you have the DVD. open up the unit and make sure all the cables and everything are tight/secure. Good luck.
Apr 24, 2007 | Magellan RoadMate 700 GPS Receiver
RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Sep 17, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 800 GPS Receiver Logo
207 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
