Question about Jon Dicks What a Carry On
What1999 Honda civic dashboard warning lights
What SRS means on the 1999 Honda civic dashboard warning lights
Fixed srs light( blinked twice) for code reset later when car started, it fired and died immediately, starter cranks but no spark or fuel?
Follow the given link, maybe you get something useful.
https://www.reliable-store.com/products/honda-civic-service-repair-manual-1996-1998-download HONDA CIVIC SERVICE REPAIR MANUAL 1996 1998 DOWNLOAD
Mar 18, 2018 | 1997 Honda Civic
What to do about srs sirbag code 1-1 in a 1999 Honda Civic?
plug in to scanner find witch air bag is at fault replace it and reset
or try plugging in scanner first to reset
Oct 23, 2014 | 1999 Honda Civic
What does the wrench warning light on my dashboard of my 2007 civic mean?
it usually means you are due for an oil change unless the last place that changed oil did not reset the light. Some Odometer displays will show you the oil life when you switch through the displays.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 28, 2012 | 2007 Honda Civic GX NGV Sedan
My SRS light just came on in my 2002 Honda Civic LX. What does it mean,and how should I fix it? Thanks.
(SRS) Safety Restraint System----- air bags etc
Same as any check light
Take to a repair shop to have it
checked for codes,diagnosed and repaired
as needed
Apr 25, 2011 | 2002 Honda Civic
Srs on dash display??
SRS means Supplemental Reinstraint System, aka AIR-BAG
This protect the driver and the friont passenger from head injury.
Oct 27, 2009 | 2002 Honda Civic
SRS light stays on
The Supplemental Restraint System (SRS) is definitely something you want working. Those airbags can be a lifesaver in an accident. Take it back to the Dealer and tell them it wasn't broke before they worked on you car, it's broke now after they worked on it, and stress how much of a Liability this might be. Okay, okay... just ask them to fix it because you would like to have it in case you are involved in an accident. My Civic's Service Repair Manual (from Honda), says Take it To Your Dealer (see below)
All SRS electrical wiring harnesses are covered with yellow insulation. Related components are located in the steering column, front console, dashboard, dashboard lower panel, and in the dashboard above the glove box.
Do not use electrical equipment on these circuits.
-WARNING
To avoid rendering the SRS inoperative, which could lead to personal iniury or death in the event ol severe frontal collision, all SRS service work must be pertormed by an authorized Honda dealer
Jul 18, 2009 | 2002 Honda S2000
Lights on dashboard
What does the picture look like (or better, the object shape)?
May 25, 2009 | 1997 Honda Civic
Srs light stays on my 2001 honda civic ex
you should have it checked at a dealer ...that means that your supplemental restraint system is not active that is your airbags....!!!!!!
Mar 11, 2009 | 2001 Honda Civic
96 honda accord airbag module......
does the srs light come on and go off at random times and sometimes stay on if that is so check the srs switch under your seat it try moving round in the seat applying weight in diff locations and see if it goes off and on if so then you might need to replace that switch
Mar 05, 2009 | 1999 Honda Accord
What does abs and srs mean on the honda civic dashboard -thanks
abs-antilock brake system srs-supplimental restraint system(air bag)
Dec 02, 2008 | 2003 Honda Civic
Facebook Apps Logo
20 people viewed this question
Top Jon Dicks Facebook Apps Experts
tony wahlman
tony wahlman
Are you a Jon Dicks Facebook App Expert? Answer questions, earn points and help others
